Results 1 to 13 of 13
GSXR caliper compatibility questions
    Branford CT
    I am building a track bike and just found out my 04 600 that has 02 1000 forks are bent. My calipers are from on 02 600. My question is what other year forks will the 02 calipers bolt too? Or should I just ditch the calipers too for new ones? Is there a list of what year parts match up? I have found alot about sv swaps, but I need GSXR to GSXR swaps.
    #277
    Jan 2009
    Middletown, Ct.
    Re: GSXR caliper compatibility questions
    Branford CT
    thanks chris, now I have to decide to stay with older forks or get get new ones with radial brakes
    #277
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Not my money so its easy for me to say. But if you have to replace it all any ways you might as well throw the best stuff on there.
    Branford CT
    I want to upgrade, just need to check if my rim will fit.
    #277
    If you can run either 06 R6 and up or 09 GSXR 1000 Monoblocks....I will have a set of 06 gsxr 600 calipers if you want to try those but being the year they are a bit more limited to what you can use..
    Branford CT
    Well I just got an offer for a full 08 600 front end with rim and all. Will that bolt up to on 04 600 frame? It sould right?
    #277
    I am not sure but I would ask on the WERA forum there may be one or two that have done the swap....lots of knowledgeable racers on there. I would think that they are very similar but then again a slight Diff may be a Lot .
    I will throw a post up on the WERA BEEB and see what shakes........................
    Here u go...
    http://forums.13x.com/showthread.php...11#post3835211
    Branford CT
    Thanks for posting that!
    #277
    No biggie, see if anyone bites....if its been done they are probably on there LOLOLOL
    twisted gixxer frenchy21's Avatar
    Aug 2010
    east providence,rhode island
    all the steering necks and triple trees from 2000-2009 are all the same on gixxers. anything between those years will fit. as far as calipers go, they all should do the trick, if u go with 06 r6 calipers you will need a 3mm spacer ( i think its 3 mm lol) hope this helps
    Here is a Reply and Thanks Frenchy..................if it is longer run a set of fork caps and drop it accordingly
    I'm assuming you're using the 08 triple also? If so, bolts right on, no issues. the forks are a bit longer.
    Branford CT
    Yes, this is the entire front end with wheel too
    #277
  1. 03 gsxr 1k throttle cable questions
    By freeskier in forum Bike Maintenance
    Last Post: 04-12-12, 09:33 PM
  2. WTB: late 80's GSXR rear caliper
    By Ray-Ray in forum Wanted
    Last Post: 01-08-12, 04:46 PM
  3. 2004/2005 GSXR 600/750 Caliper bolt
    By wiggeywackyo in forum Wanted
    Last Post: 07-19-11, 04:00 PM
  4. WTB Front Caliper Suzuki GSXR 600 '01-'03
    By FirstLightning in forum Wanted
    Last Post: 07-03-10, 06:33 PM
  5. needed ASAP: '01-'03 gsxr rear caliper
    By Kitt in forum Pit Area
    Last Post: 06-10-08, 02:31 PM
