Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
what really happens to the oil
    Lifer Currently's Avatar
    Ooltewah, TN
    Re: what really happens to the oil
    Pssst... post #7... good reading...
    Screw reading ... I want to watch!
    If loud pipes save lives, imagine what learning to ride would do.
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Quote Originally Posted by DuncanMoto View Post
    You can all stop being such pussies and just get some electric gear and not put the bike away for the winter.
    Pussies? I'll show you a pussy!!!
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Tucson, AZ
    I'm supposed to read a thread before posting
    Original
    Leo loridin64's Avatar
    Outside Lowell
    yep
    me too. I start the bike every two weeks and run for 10 mins
    yep. and i have just over 3000 on my oil. not worried about it. ill get to it in the spring
    2002 RC51
    USMC - Semper Fi
    POW/MIA - Not Forgotten
    yep
    I ride at least once a week, last week, I got in over 500 miles, been averaging about 300/week since I put my winter tires on and had my 30k service 5 weeks ago
    LRRS Rider #256 QuarterGig's Avatar
    Gorham Maine
    still riding.. most every day to work ..
    i put stabul in my girls bike and put it on the tender. race bike got stabul, radiator drain and the tender.. none of the rest have fuel in the or batteries so they are as they are.
    changing oil seems excessive to me.
    Seth
    LRRS/CCS NV #256
    2007 Ducati S2R1000 Street
    2000 Triumph TT600 Track For Sale
    1984 Honda Magna needing reassembly.
    1974 Honda CB 750 needs wiring
    1974 Honda CB 350 needs engine work
    Dec 2008
    Old oil left in a motor can cause damage to bearings as well i had a couple of main bearing failures that were traced back to chemical etching of the bearing race. The race then fretts (flakes) and self destructs.
    How old is too old an oil? I think it depends on so many factors, blow-by being the main one. In a motor that turns the oil dark soon I would change the oil sooner. I have seen some bikes go 5000 miles and have the oil look new. This is not a typical track bike, hard use needs more/sooner changes.
    If the oil is pretty fresh and looks so you are "probably" safe. if your new oil looks black I would change it as cheap insurance. When spring hits I would take the bike out and ride it as the oil has been not used while sitting.
    ooops! time to change my oil.
    Oct 2005
    Wrentham MA
    So if I leave oil (full synthetic) with 1000 miles on it in my bike for the winter what happens that is bad?
    will the bike grow a third cylinder?
    Nothing! As long as ....................
    You make sure the last time you ride it - do at least 30 miles to get it hot (out-gas all the bad caustic shit...)
    The worst thing is to start once in a while....
    (I have stored bikes for years this way - as well as some fogging oil in the motor, lots of stabil - full tank etc).
    Today's pump gas has enough detergent stuff to protect your upper cylinder wintering-over - but stabl in the fuel is a must
    Graham
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Just in case mine gets a squirt of fogging oil down the filler and run for a bit to distribute.
    I still like to just put in cheap dyno oil and a new filter for the winter and leave the plastic off
    then after a short run or 2 in the spring
    I just change oil to synthetic leaving the filter of last fall
    gixer 13K never used a drop of anything
    Glen Beck is John the Baptist
    Raymond NH
    Question for those who change oil frequently:
    How many miles do you intend to put on your bikes?
    Shocking as it may seem, these engines are actually designed to operate just fine with used motor oil. Unless you change your oil every time you shut your engine off, you are using the dreaded used motor oil practically all the time too.
    I kept my last bike until it had 100,000+ miles and my current bike has about 70,000 miles. Both had/have oil changes every 6000 miles or so with no special oil changes prior to storage and both ran/run fine. The valves wear out faster than the bearings or rings on my motorcycle engines.
    I follow the recommended maintenance schedule in the owners manual, 100% dealer service, my SV made it to 135k, loose valve guides, stretched cam chains, consumed oil co-incidental with long interstate rides, never regular til the last 3000-4000 miles, when it was smokin was just startups and near redline acceleration and throttle chops
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Jees Randy...you've got 30k on the Strom already? Hardcore.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Dec 2008
    The flip side is also changing the oil too often.
    next time you change oil watch how long it takes to get your oil pressure light to turn off.
    On a Ducati it is quite a while. A lot of owners do 1000 mile changes (trying to help their bike) , Multiply the time the oil pressure is low times the number of oil changes in 10,000 miles and you could be doing more harm than good.
    Again as most oil gurus will tell you the oil is more than up to the task to long intervals, as long as you are using a good oil to begin with. Where the concern with old oil comes from is what else has made its way into the oil with use.
    I have seen plenty of motors that have seen nothing but abuse, some never have a problem. That does not mean I am going to ride around with my oil pressure light on and not check it out. hanging your oil is something most home mechanics can do and I very much believe it can be cheap insurance.
    lost in space zombie's Avatar
    6000 mile intervals with synthetic oil changes
    ride the fucking thing year round
    almost 60k on it and still not using oil
    eat me
    Jul 2008
    Waitsfield, Vermont
    Quote Originally Posted by ducvet View Post
    If it's physically possible with the style of oil filter you use, you may be able to fill the new filter with oil prior to installing it; in some cases, this will dramatically shorten the low-pressure startup time.
    Dec 2005
    Near The Dragon
    Wirelessly posted (BlackBerry9530/4.7.0.75 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Quote Originally Posted by kbroderick
    Flip side: trying to prime a pumpthat is not submerged while trying to pump air through an oil filled filter can air-lock your lubricating system completely preventing the pump from ever priming until you loosrn the ilter and start it.
    Trust me on this.
    Get out while you can
    Find your own path
    Dec 2008
    +1
    you never want to cram too much oil in the filter. even with a partially filled filter it takes longer to get pressure than I would like.
    Dec 2008
    now that I think about it probably worse to have me throw the thing on its side once in a while... lol
    I may need a tether switch.
