https://www.harborfreight.com/genera...arb-70143.html
new 5000w inverter generator
Man, I remember when I was holding out for that lift to be around $275...
John
CCS/LRRS Expert #69
LRRS Rookie of the Year 2004
I thought my HF oil pressure gauge kit was good. Two years later it leaks ATF at the hose/gauge connector.
2013 ZX6R-636
normally I just buy HF stuff and see what happens myself, but this is a bit pricey, SO anyone picked up this torque screwdriver kit??
QUINN10-50 in. lb. Precision Torque Screwdriver Set
https://www.harborfreight.com/10-50-...ece-58950.html
thoughts / opinions??
Also, what's the deal with newer line of DOYLE hand tools they have?? "Above Pittsburg / below Icon" type deal?!?
I’ve been using the US General magnetic can holder and can confirm it holds up to some abuse, especially on those stubborn projects. Highly recommend.
https://www.harborfreight.com/tool-s...ray-59851.html
Picked up one of these for 90 bucks last week to compliment my 5 drawer. It's pretty nice. Rolls super easily, almost too easily. Heavy duty sliders on the drawer so you can really pack it. Highly recommend at that price point.
what is the opening diameter on this?...i have been looking for a cheap but durable cup holder for my beach chair...the one it comes with is fabric and sags when you use it and you can't put a thermos cup in it...i would just remove the magnets and screw it into the arm
Anyone rocking the new black tire changer? I like the upgraded rubber pads and want to switch to it from the older red one but I want to make sure my motorcycle tire changer can fit on it. On the old red one they changed the thread pitch so the motorcycle adaptor doesn't fit on all of them.
https://www.harborfreight.com/manual...hoCYugQAvD_BwE
I tell you I have one of those predator 3500 inverter generators. That thing is super quiet and has been reliable for a few years.
Lost the keys to a Master padlock and will have to cut it off.
Does HF make a good angle grinder / cutoff blade combo? Seems like many models from
Do the battery powered models have enough power for use around the shop? Models from $20 to $100.
https://www.harborfreight.com/power-tools/grinders.html
I have el cheapo chicago electric angle grinder from HF. It has to be 15 years old and I've abused it. Still works great.
If you have other battery tools of theirs, then maybe the battery one would make sense? But I don't want to get in to another battery system. So if I'm looking at HF for a cheap tool, then I want the cheapest one that will get the job done.
And if I really want something battery powered, then I'd be looking at Milwaukee since I've been switching over to them.
2003 ZX7R
1995 916
Get the corded one. I beat the piss out of my cheapo $15 one and it has never given me an issue. Currently i have an illegal saw blade ripper mounted to so i can groove pieces of decking for traction and scare myself silly while using it. Good times...
Never buy battery powered tools from Harbor freight. They usually change the design up every few years so your tools get out dated quickly.
