Results 1 to 12 of 12
Honda XR100R: Idle Not Found
    We have an old (1994, I think) XR100R that starts well and runs well. But it will not idle even after warmup.
    It will run at the half-choke setting, albeit with elevated idle speed. Fuel is good, even added some conditioner a while ago.
    Is there a maintenance manual on line or should I buy a Chilton or something else?
    It looks like there is a screw at the bottom of the carb that might be a drain? Not sure where to start - haven't owned a carbed bike for more than five years. I bought one of those HF ultrasonic tanks so if I have to remove it and clean it, I have a fighting chance.
    Any good maintenance websites?
    Re: Honda XR100R: Idle Not Found
    Update, found some carb cleaning videos on youtube.
    Wirelessly posted
    Its the pilot jet. Take it out and clean it in the US cleaner.
    That was easy. Took the carb off and it appears to be a replacement: doesn't look like something 20 years old. Took the jets out and put them in the [Harbor Freight Ultrasonic] cleaner for about five minutes. Put it all back together and it starts first kick and idles nicely.
    This is the video I watched: there are many as it turns out. About as easy a maintenance as there is.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    What do you mean put the jets "in" the cleaner? If there's an easier way, tell me! I usually spray them down with carb cleaner and then make sure there is no blockage with a piece of safety wire.
    Maybe meant an ultrasonic cleaner?
    Regardless, XR100's (among many single carb thumpers) are the easiest to clean and tune...I sure do excited when I go to look at one and the previous owner lowers the price since the bike won't idle, and he keeps the choke on halfway to keep it running...
    What do you mean put the jets "in" the cleaner? /.
    NESR approved ultrasonic tank.
    http://www.nestreetriders.com/forum/...-gotta-get-one!
    Central MA
    The low speed jet on an XR100 is so small that, more than likely, a piece of safety wire will not go through it. I usually have to clip one strand off of a fine brass or steel brush. The hole in those things is *tiny*.
    What did you use for cleaning solvent? Simple green?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    also try a twist tie off a loaf of bread...
    Posted by Jane in BoxChat
    The cleaner HF sells with it. You use a 1/4 teaspoon. Whatever it was worked, I could see the inky stuff coming off almost as soon as I started it.
    Lifer Stromper's Avatar
    Eastern Ct
    Add a lawnmower paper element fuel filter for happiness
    pilot jets clog with micromicro grit
    The calculus of hate
  1. Honda XR80 wont idle
    By U.S.A in forum Bike Maintenance
    Last Post: 07-18-14, 09:10 AM
  2. For Sale - Motorcycles | 1994 Honda XR100R - in Boston
    By Garandman in forum For Sale
    Last Post: 06-21-14, 07:01 AM
  3. For Sale - Motorcycles | 2003 Honda XR100R
    By oVTo in forum For Sale
    Last Post: 06-10-14, 06:52 PM
  4. 2000 Honda XR100R
    By Doc in forum Dirty Bastards
    Last Post: 03-13-07, 06:25 AM
