Is there a way to bypass this safety feature? Is it as easy as unplugging the switch wire?
When the kickstand is down I cannot run the bike what so ever... Not sure if thats how this model was set up, or if it's a malfunction?
www.tailofthedragon.com
A kickstand switch is typically just a simple switch, so usually you can just remove it/unplug it.
Cheers,
Chris
Yeah, but some bikes will let you start them in neutral with the kickstand down, but others won't (Ducati ST4 as an example). In other words, the kickstand switch only acts as a kill switch if the bike is in gear, but if its in neutral you can start the bike normally...Originally posted by Mystery Squid
Not a malfunction... same goes for my bike, it's to prevent you from riding off with the kickstand down.
Personally, I start the bike with the kickstand down quite alot, and if I couldn't start it in neutral with kickstand down, I'd be pulling out that switch fast-like.
Cheers,
Chris
werd... i almost always start the bike when i'm putting on my gear & not on the bike... unless it's already warmed up, then i'm on it & hittin the starter. but if it's cold, i start it up before throwing on my stuff & don't get on it till i'm ready to goOriginally posted by hohum
Cheers,
Chris
but i guess this doesn't help Halfie
Do ya have a manual w/a wiring diagram Mike?? You should be able to by-pass the kick stand switch w/out much work.....you may haveto just ground ou the wire
I'm glad my bike doesnt have that....it would drive me up da wall
Honda (RC26) VFR700
"hey Randy, do a wheelie!!"
I didn't even get a freakin owners manual.. Forget wiring diagram... I am just going to disconnect it.. Fuggit..Originally posted by wastedincome420
Do ya have a manual w/a wiring diagram Mike??![]()
Thanks for the help peeps...Going to get the battery after work and throw it in and hopefully take a test ride around a few quick back roads to see what else is up with the bike... Hopefully it will be ready to rock and roll next week and I can schedule an appt with the state insp for a reconstr title...
The switch is either normally open or normally closed. If you unplug the switch and the bike doesn't start at all jumper, the wires together and it should start up regardless of the kickstand position. Good Luck...
SSearchVT
Um yup, I unplugged it and no starty... So what do you mean to jumper the wires, switch the connections over.Originally posted by SSearchVT
The switch is either normally open or normally closed. If you unplug the switch and the bike doesn't start at all jumper, the wires together and it should start up regardless of the kickstand position. Good Luck...Theres only two wires.. So try changing the two connections??
He means to try holding the two wires for the switch together to complete the circuit. (jumpering them)
Either the switch acts as cutoff in the open position (in which case if you unplugged it it should run and start with no problems), or the switch acts as a cutoff in the closed position (which seems like its your case, so tape the two wires together to complete the circuit and see if it starts)
Cheers,
Chris
Make sure the switch is properly in place, i know one of the bolts that holds it in place sometime loosens up and falls out on the pre 02 models.Originally posted by Half Squid
The R1 should start with the sidestand down as long as the bike is not in gear. If it's in gear and the sidestand is down, it will not start even if you pull the clutch in. Does the neutral light work? It's all directly related and if someone hacked up the harness when they stole the bike, they could very well have cut a wire?
It's not a good idea to bypass a safety feature like that and there's probably a good chance something like that would be checked when you apply for the reconstruction title and inspection
Yeah Mark, there is no Nuetral light while in Nuetral, so your on to something here! Bike starts fine with kick stand up in nuetral or in gear with the clutch in. Will not start either way with stand down... Did you have to pull the clutch in on your 98 to start even in nuetral???
I'll investigate further!!![]()
No, i didn't need to pull in the clutch while in neutral to start it. You've either got a bad neutral switch or a wire has been cut, nothing is wrong with the sidestand switch, if the neutral switch was working properly, it would override the sidestand switch.
I had the R1 service manual but i gave it to Todd to use if and when he ever puts his R1 back together![]()
