Results 1 to 25 of 26
What is "routine maintenance" for a race bike.
    Lifer Pittenger5's Avatar
    Austin
    So be honest, what do you do regularly in terms of maintenance.
    So far all I've done is oil changes, brakes, and check nuts and bolts/chain etc.
    How often do you guys get into other things? Engine, clutch, etc. Or do you just wait until there's a reason to check it.
    08 CBR 600 if that makes any difference.
    Zip Tie Alley #505
    Re: What is "routine maintenance" for a race bike.
    Coolant and brake fluid every 2 years. Valve check at 16k. Suspension fluid every 3 years or so for street. That would be my schedule for that bike
    Lifer PhilB's Avatar
    Jan 2012
    Pittsfield, NH
    Depends on your bike, and how much you ride. For me, the most frequent maintenance is the normal chain lube, check oil and add if needed, check tire pressures, check bulbs -- all of that happens about once a week (about 500 miles). Oil change, check brake pads twice a year (about 6 to 9K). Check valve clearances and clutch throwout bearing once a year (12 to 18K). Inspection once a year. Cambelts, fork oil, brake and clutch fluid, check clutch plates every two years (24 to 36K). Anything else only if it causes a problem. Valve guide seals are needed about every 50K. Brake disks, clutch basket, steering head bearing, wheel bearings are needed about every 100K.
    PhilB
    Quote Originally Posted by PhilB View Post
    PhilB
    How do you afford so much track time? 12-18k in a year is a lot for a racebike
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    On my race bike.. Go over looking for loose and broken bits. Fresh brake fluid twice a season. Clean calipers a couple times per season. Oil and filter a couple times per season. Check valve clearance once a year. Twice if I have time to kill. Clean and lightly lube chain between rounds
    For me working on the bike is relaxing. I'm in the basement with the bike on a table and just puttering and relaxing.
    Jan 2012
    Pittsfield, NH
    D'oh. I didn't read the question fully. Sorry.
    PhilB
    PhilB
    bulbs ? on a race bike
    Warning lights.
    • flush & refill the radiator beginning and mid season.
    • replace brake fluid beginning and mid season.
    • push caliper pistons out and clean with simple green every 2 weekends
    • oil change every 3 weekends
    • oil filter change every other oil change
    • clean/adjust chain every weekend
    • clean air filter beginning of the season
    • check spark plugs beginning and before Daytona
    • check rearset bolts every weekend
    • adjust clutch plates every other weekend
    • refresh suspension (forks, shock, damper) every 10 hours of use
    Just buy a new one before it breaks.
    Haverhill, MA
    the plates get tight from starts. it's something Frenchy does for me, since it takes him 2 seconds. you take off the 17mm nut on the clutch cover and adjust the play in the plates. i think it's a 12mm and 14mm lock nuts.
    Shit, don't you guys ever put GAS in your bikes? I do that after every single race.
    Good list jimmy. Although I've never heard of the clutch plates thing either.
    If your stack height is varying THAT MUCH in that short of a window, you've got mechanical or technique issues I'd think.
    it's not bad. it's just a check or small adjustment. i can tell when it's time with how my starts are. i'll make an adjustment and it's night & day.
    it's been that way on all my stock motors, so it's not a mechanical issue
    Adjusting clutch plates?
    What he's talking about is adjusting the clutch pushrod free play. An adjustment that should never need to be touched once set against a clutch that's in the proper stack height range. If you have to do this on multiple bikes I go back to a technique question as you're rapidly burning your clutch pack out. How long are you going between clutch pack swaps?
    i've never replaced a clutch
    Haverhill, MA
    Didn't realize the Suzukis had adjustable push rods.
    Just about every bike has an adjustment for the clutch mechanism at the business end when running a cable. That sets the free play for the push rod / pressure plate interface, you then adjust cable slack in the cable or at the lever. I know it's got a proper name but I'll be damned if I can think of it at the moment and I'm too lazy to google.
    go faster cdovego's Avatar
    Weymouth
    What about those dreaded motards? Don't you have to visit a priest every month with them for a fresh blessing on top of brakes/chain/gas/tires/oil/clutch?
    Central Mass Powersports #123
    Mine gets fresh oil with every gas top off.
    Austin
    Just make sure you drain the old oil first .... not that Id know anything about that.
    Zip Tie Alley #505
    Weymouth
    You guys change the oil? That seems like a waste. It burns off when it's no good anymore.
  1. For Sale - Motorcycles | Honda Hawk GT Stage 2 Race Bike "Pegasus" For Sale
    By MikeBike in forum For Sale
    Last Post: 10-17-15, 07:55 AM
  2. 2006 "Black Sheep Squadron" R6 race bike - $6000 obo
    By OreoGaborio in forum For Sale
    Last Post: 02-13-11, 06:32 PM
  3. Routine Weekly Maintenance?
    By hurstshifter in forum Bike Maintenance
    Last Post: 03-27-09, 05:44 PM
  4. Finding the "right" track or race bike
    By The Snowman in forum Pit Area
    Last Post: 11-30-08, 11:39 AM
  5. Routine Maintenance
    By Boner in forum Bike Maintenance
    Last Post: 07-10-06, 09:22 PM
