I'm having a little issue with my CBR. Short of getting a new bike (as I KNOW some will suggest, since we're all smart-asses here)
I get a low-rpm bog between 2K and 3K. I thought it might be something in the fuel system, so I ran a full 16oz. can of Seafoam through one tankfull of gas with no change.
I've also cleaned my air filters (I have a Factory Air Box Plus jet kit installed, which requires the modification of the air box to accommodate their dual foam filters. They're cleaned just like you would a dirty-bike's filters.) Same thing, no results.
Looking for other things to try, short of tearing the carbs apart. I'm going to check the plugs next for fouling.
Any other suggestions? (no, I'm not getting a new bike anytime soon)
Is it very specifically in that RPM range, or does it vary some?
If its that specific, I'd be looking for something in the ignition system rather than the fuel system.....![]()
It's around that point and goes away after about 3K. It sounds like the bike is being fuel-starved. (like the older bikes that were running out on the main gas tank and needed to manually bne switched to reserve [like mine]).
For Red: Sea Foam Info
I tried Techron originally and it didn't work.
I tend to use 87 octane gas and usually from the same location. (yes, it's a Cumby's I usually go to) It's run great since I bought it last June. Think I should try higher octane gas with more detergent? (like Shell?)
ditto the clean the jets comments.
2003 ZX7R
1995 916
They're not fouled. You've been riding the bike for years, why would they suddenly foul? No reason. Plus, fouled plugs wouldn't run well at higher rpms either.
If you got that far, just go for it. Unhook the cables and pull the rak out. Take the bowls off the bottom, and remove the brass jet that has a slot for a flatblade screwdriver. Clean as above, replace and reassemble the mess.
True. I put them in back in December and have put about 4K on it since.
It's called fear of completely fucking the thing up. Last time I messed with a carburetor, it was on a single-carb quad and I ended up having to bring it to a dealership to fix what I had screwed up. I'd rather pay someone I trust to look at it.
get a new...damn you beat me to it
jk chuck
if you want once again i will offer my help to work on your bike, and what the hell you might learn something
I had Degsy tear into the carbs. He cleaned all the mains jets, the pilot jets, the float bowls, and the floats.
The problem still exists, IMO. Degs said he thought he didn't see a problem, but it's definitely different from what it was a few weeks ago.
So, what next? The ignition system? The plugs aren't fouled. Spark leak? Wires? Coils?
OY!!!![]()
I'm gonna say it's electrical, If it was fuel or air problem it would bog all the way through, and worse at High RPM's then low.. I guess you should start at the ignition.. Pull out the walled nad start replacing parts, I'm sure there are way to test it and maybe eliminate some choices, maybe someone else can chime in that knows more then I do about the ignition system on a bike..
Check your output voltage from the stator and rectifier? I know my old pig used to be really picky on how it ran with a low battery, and especially when the rectifier melted itself.![]()
Just for shits and grins, raise the needles up a notch.
If it runs well WFO then I wouldn't think it would be ignition, because that's when you need the voltage at the coils to light a leaner mix.
In any case, if someone just came to me and said it bogged right around those rpms, I would suspect lean, and go after the needle/needle jet.
Since you said you never had a problem, and then all of a sudden it starts, and if the carbs check out OK..(did he check fuel level in the bowls?), I would look at other things...If You just recently replaced the airfilter with a different brand, would put up a flag. I would next do a leak down/check valve lash, just to make sure conditions are correct in the cylinders, and while I was at it, I would double check cam alignment, and the cam chain tensioner. Just some food for thought.
Mark Chucks like Oddball on the dirty dozen, he just rides um he don't fix um man!
www.bostonmoto.com
Forum Rules
BTW, it looks like it's starting to work itself out. After I cleaned and reoiled the foam air filters (the bike has a Factory Air Box Plus kit), and asked Degsy to run through the jets (np, he didn't check the fuel level in the float bowls), and ran the tank out of Sea Foam and/or any bad gas that might've contaminated the system, it seems to be working itself out.
Hopefully, this might be the end of this particular situation. Time will tell.
