I ordered new hoops for my Ape and must have had a brain fart when placing the order. I ended up with a 120/60 front, when the bike calls for a 120/70 front. By the specs, the inflated circumference is about 1" difference between the 2.
First question, what's the handling difference and how will it change it?
Second question, (probably best to call the dealer on this one) it's an RSV4 with APRC and I know things get a little wanky just with simple tire changes...After I reset the APRC system, will it still work properly with a smaller diameter tire?
edit.. I did order a 120/70, just not sure if it'll make it here by Friday or not..which meens I have to put the 120/60 on for the weekend
24 mm.![]()
CAR tire math doesn't work with motorcycle tires
I put a 120/60 on a GSXR-750 years ago and tipped into corners much too aggressive for my tastes.
R.I.P. - Reed - 3-23-2008
LRRS EX 66
factoryeffex
Wirelessly posted
Its a Pirelli Corsa. So the quicker turn in may not be a bad thing seeing the bike is a bit porky?Originally Posted by Paul_E_D
So next question is how the APRC reacts, I'll give seacoast a call on that.
Thanks for the reply
I have ran both 120/60s and 120/70s on my SV,
the 120/60s are quicker turn in, twitchy compared to the 120/70, more midcorner corrections cause of the quicker turn in, also less sidewall to protect wheels if you get into any rough stuff
You won't notice it at your speed!
