Page 18 of 24 FirstFirst ... 89101112131415161718192021222324 LastLast
Results 426 to 450 of 590
100 DAYS UNTILL 2014 RACE SEASON
  1. #426
    Apr 2011
    NH
    Re: 100 DAYS UNTILL 2014 RACE SEASON
    I need to loosen up the front end to get the front wheel spinning better.
    it should just spin on its bearings. unless the axle is bent I'd look at the bearing or brakes. If the forks are not aligned it would be hard to get the axle through.
    Tim
    LRRS #44
    Superbike Services 44
  2. #427
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by timmyho414 View Post
    everything isn't aligned right. I just put the forks and wheel back on. didn't have the room in the shed to do a proper bounce to get it all lined up. easy fix. nothing bent.
    Woo Hoo!! I'm done! Both the RSV and SV are ready. I spent the day changing fluids on both bikes and inspecting the rest of both bikes to make sure I didn't miss anything.
    Too bad I'm not doing round 1.
  4. #429
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Just sent in my pre reg for Super Singles , Motard .............. and Ultra light Superbike, Geno and I have some mixing it up to do!
    Aw crap, another one of them dirty bikes soiling our pristine ULSB class...
    Oct 2007
    Littleton NH
    ohh and Larsnic will be on one as well, and Wild Bill Hiccok might ride his 560smr instead of the Hawk......
    Oct 2007
    Littleton NH
    Besides I have 0 points in the series , I will be in the waaaaaaaaaaaaaaayyyyyyyyyyy back
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by lrrs428 View Post
    I've been debating if I should pick up ultra light superbike and drop motard just to make my weekend shorter. I hate waiting around on Sunday for the last race.
    James
  9. #434
    Durham
    Got a lot done this weekend and was feeling pretty good about it until I thought about everything that's left still. Waiting on some stupid little hardware bits before I can get the rear wheel on or bleed the rear brakes. Chain, bleed the front brakes, fill with oil and water, mount the upper and lower (still need a damn windshield), paint, change bearings in my rain wheels, finish rewiring for keyless ignition, and you know, actually start the bike.
    Got the motor all wired up though, and a bunch of other stuff done. Even took some time to retrofit my trailer with brakes. Still have to wire them in but the mechanicals are all there.
    I need to loosen up the front end to get the front wheel spinning better. swap the coolant and oil. wire up the wheels/suspension and throw the bodywork back on. all easy stuff that'll take an afternoon.
    mine was the buttons on my rotors werent floating. had to clean the debris around the back of the buttons
  11. #436
    Meriden, Ct
    Getting there....
    Bike is ready (mechanically)
    Bodywork and paint is well under way. All glass repairs are done, body filler done, everything sanded and scuffed. Tank cover, upper, and tail are primed. Still working on lower (prior owner covered the fucking thing is stickers that refuse to let go... still painfully working with a razor blade). Everything will be painted by the end of the week.
    Confirmed with Wanda that she finally processed my license (# retained)
    Spent last night measuring and cutting all the E-Trac for the trailer (back of my left hand is mildly burned from holding the E-Trac against the chop saw. apparently two hours of throwing sparks against your hand will do that.)
    Installing E-Trac, TRS, and lights into the trailer on Wednesday night and calling the trailer done.
    Oct 2007
    Littleton NH
    16 Days folks
    Apr 2011
    NH
    dropped my bike at Seacoast to have them break in the motor for me. They should be doing it on my birthday so that must be a good sign right?
    also mounted the belly pan on my 748 so my back up bike is just about done. can't really do the belts in the living room, what with having to pull the tank and all.
    Tim
    LRRS #44
  14. #439
    Branford CT
    Bodywork on sort of, need to trim some.
    #277
  15. #440
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Just have to safety wire the new bike and finish up mounting the throttle. I don't know why, but for some reason I don't have much interest in racing right now. Maybe I'll skip a couple rounds if I feel the same way in the coming weeks.
    Wheels on and wired. Carbs will be on the dining room table shortly for some minor TLC. All that will be left is deciding on a final airbox setup and matching pump/plumbing, syncing, and throwing the body work on. Then I can fit the Pitbull TRS to the trailer and...
    CRAP 16 days?!
    Apr 2011
    NH
    sorry Kurlon, 15 days
    Tim
    LRRS #44
  18. #443
    May 2010
    Somersworth, NH
    Picked up a couple gal of fuel last night now that the bike is painted and together. It took some coaxing but eventually fired up. Mustve been a stuck bowl float on the rear cyl carb cuz gas was slowly coming out of the overflow tube. Checked the float and reassembled. No more overflow but now there is mysterious smoke at idle coming from what appears to be the area around the back of the rear cyl at idle. Will investigate further. :/
  19. #444
    Oct 2007
    Littleton NH
    Just found out I need a right side center case............... Fuck my life , might be rippin the B bike the first round if the parts don't get here quick enough
    Durham
    New livery is mostly laid out so I can get started on the paint finally. Hoping that I can work efficiently and get the mechanicals finished up in between coats of paint rather than letting anything sit while I work on something else.
    Did you have that area apart for any reason? Did you spill and gas or oil? Did you use any penetrating lube on ANYTHING in that general area? If you can answer yes to any of these I would just run it and get it good and hot, it'll most likely go away on it's own. It's not at all uncommon for some sort of fluid or chemical to end up on or near the engine after a rebuild of any kind. First time it's started and gets some heat in it that stuff burns off and you get weird smoke like what you're seeing.
    Haverhill, MA
    Sucks bud! Hope you get it all squared away quickly.
    May 2010
    Somersworth, NH
    Quote Originally Posted by soofle616 View Post
    Thats really what im hoping. didnt have that area apart at all. gotta look into it tonite.
  23. #448
    May 2010
    Somersworth, NH
    Yup ended up just being stuff on the pipes burning off phew
  24. #449
    Senior Member WinVT's Avatar
    Winooski VT
    Crap, do I have to start getting my bike ready??
    LRRS #313
  25. #450
    Oct 2007
    Littleton NH
    14 Days
  1. 49 days till race season starts
    By Jim in forum Pit Area
    Last Post: 03-11-16, 12:31 PM
  2. 94 DAYS UNTILL 2015 LRRS RACE SEASON!!!!!
    By lrrs428 in forum Pit Area
    Last Post: 05-14-15, 05:10 AM
  3. 2014 race season...
    By DZircher in forum Pit Area
    Last Post: 09-28-13, 12:42 AM
  4. Count Down Untill 2013 Season Kicks Off!
    By lrrs428 in forum General Bike Related
    Last Post: 04-29-13, 12:49 PM
  5. Count Down Untill 2012 Season!
    Last Post: 04-28-12, 07:19 AM
