Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 137
heated gear?
  1. #51
    Re: heated gear?
    30's in the morning and have not tapped into the heated stuff yet.
    although cold tires and freshly damp roads = loose rear end and skidding stops
    Me neither, but I want heated gloves badly....
  2. #52
    Re: heated gear?
    that's hamfistedness on your part
  3. #53
    New Haven-ish, CT
    Re: heated gear?
    Quote Originally Posted by gamorg02 View Post
    if you go buy one of the kits you put under regular grips don't go with the tusk (could be other names for it) one where there is a resistor. first off i don't like the 'low' setting just putting out heat elswhere (resistor) and secondly the pads are of a lesser quality.
    something like this is the kind i'd recommend:
    http://www.casporttouring.com/cst/motorcycle/16011.html
    if you replace the resistor with a 2-pin flasher relay, it pulses the heaters on and off (like a turn signal, duh) for a low setting, this saving ~50% power.
    Can't comment on the quality of the pads, but I just put those Symtec's on my FZ, and have a set of Cycle Gear Trackside brand ones to go on my DR.
  4. #54
    Re: heated gear?
    i tapped directly into the headlight line for the vmax and the fan line for the hawk.
    I bought a kit like that off fleabay for like $5. I took the money I 'saved' on that purchase and invested in a nice Warm 'n Safe hard-mount controller for the grips. This is (IIRC) an adjustable switching supply, not a resistor. So theoretically my draw is lower when I turn the heat down.
    The $5 heating elements were a temporary solution. Although they have worked okay. 2 seasons later and they are only marginally heating now. They were never as effective as I hoped as I mounted them under the grips which have grip-puppies on them. So there is a lot of material between my paws and the heating elements.
    I may cheap out again and get another $5 set and mount them between the grips and the grip-puppies this time. $5 every couple of seasons is reasonable money.
    Re: heated gear?
    This just in:
    http://www.motorcyclegear.com/street...er_gloves.html
    $188 with free shipping and a $30 gift card. Fuck.
  6. #56
    Raymond NH
    Re: heated gear?
    If that extra heat is not going to the resistor, it simply goes to the regulator. Most of our bikes have permanent magnet charging systems that waste excess power as heat. That resistor might actually prolong the life of your regulator. Oddly, the typical motorcycle charging system is happiest and will last longest when output power from the regulator is at max power. That said, if you need that power elsewhere because of other loads, then a resistor-based low setting is not desirable.
    I93/495
    Re: heated gear?
    This just in:
    $116
    http://www.motorcyclecloseouts.com/s...c+rider+gloves
    Re: heated gear?
    I can't tell if those cone with the wiring and junk...
  9. #59
    I93/495
    Re: heated gear?
    My guess would be probably not. Which is the better deal would depend on if you already had the bike wired or not.
    Re: heated gear?
    I don't. But it's coming. It's inevitable.
  11. #61
    I93/495
    Re: heated gear?
    Best investment on accessories I ever made.
    Ride until they salt the roads; bike usually comes back out in March sometime. Nice and comfy.
    Re: heated gear?
    This just in:
    I have those. well maybe the first gen ones.
  13. #63
    Re: heated gear?
    Gloves only, just called.
  14. #64
    Re: heated gear?
    mine came with the cables and controller. Ted treated us well.
  15. #65
    Re: heated gear?
    I gotta figure out sizes. I think I'm going to pull the trigger on Firstgear stuff from MC closeouts. This looks like the jacket for me.
    Jan 2010
    cny
    Re: heated gear?
    not a bad idea. the symtecs are on the vmax and work well. i put the 'tusk' ones on the hawk and the leads snapped twice on me, i tried a replacement set and they are good so far but put extra tape around where the leads are.
    yea not a bad idea with the adjuster and i couldn't imagine mine working well either with grip puppes. I just have one layer of rubber grips over each (oury on the hawk, stock on vmax).
    not sure i explained myself well. I took the resistor circuit right off as i didn't want to hide a .25"x.25" x 4" box that could get who knows how hot when the system was on low. I prefer the non-resistor setup as they actually have a different path (i assume shorter length of wire) through the grips for the low setting without having another piece of the circuit heat up instead.
    plus the pads are better built on the non-resistor symtec setup.
    New Haven-ish, CT
    Re: heated gear?
    If you don't want to use the resistor, there's also a way to use a DPDT switch to switch them so they are either in parellel (high = 100% power) or in series (low = 25% power). I don't recall the wiring diagram, but I'm sure you could find it online.
    Jan 2010
    cny
    Re: heated gear?
    I already cut it off and just use on/off on the high setting.
    Re: heated gear?
    wait...I have the ones you posted...and the switch is what's a PITA for me...I don't like the size, the pins are exposed to the elements, and it's an awkward shape
    how do you cut it off and use on/off on the high setting?
    I'd be happy with a pre-wired automotive switch like this:
  20. #70
    Jan 2010
    cny
    Re: heated gear?
    on the symtec ones i still use low-high as i found a small place on the vmax plastics that can hold it well.
    on the 'tusk' ones i just cut out the low circuit out completely and put a waterproof on/off switch on the handlebars. It doesn't 'click' well with big gloves on so i need to find something better for next year.
    pic:
    Re: heated gear?
    ok nvm...I'll figure out something for that darned switch
    any idea what kind is it? SPST? DPDT? SPDT? DPST? XXXX? YYYY? WTFWTFWTF?
    that one looks pretty snazzy though!
  22. #72
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Re: heated gear?
    +1
    Re: heated gear?
    okay, retarded question - does the throttle heater element go between the plastic throttle thing, and the grip? or between the clip on and the plastic throttle thing?
    finally did a quick and dirty install today...didn't have any JB weld and just slid the grip right on top...didn't have any automotive primary wire, so I just used what I had in the house...don't have the switch mounted (just hanging)...
    but good news - it works!!
  24. #74
    Re: heated gear?
    Tube and grip. Although I really want to tell you bar and tube just because that's almost dumber than anything that's been posted here in a while.
    Alright, nevermind, there's been fucktons of asinine political garbage...
  25. #75
    Re: heated gear?
    pfft... you're just fussy because hands are just cold...go get those heated gloves already!
    but that's what I thought...the instructions say "The Throttle side heater is installed on the throttle sleeve under the rubber cover."
    first ride on "hi" they took a little while to heat up...so I though "meh, they're just lukewarm"...but on my return trip the clip ons were already warmed (?) so it got nice and toasty quickly
    bike's electrical seemed to handle it just fine...under load turning it on showed no dimming; just slight dimming when idling
    also installed an LED taillight flasher thingie today...add my Sena and I'm techie'd out...my oldie fzr is the ride of the future
  1. WTB Heated gear
    By hondarider102 in forum Wanted
    Last Post: 10-19-10, 09:36 AM
  2. Heated Gear?
    By Danz19899 in forum General Bike Related
    Last Post: 02-22-10, 01:21 PM
  3. Heated gear???'s
    Last Post: 10-17-09, 04:01 PM
  4. Who's got heated gear?
    By Tricky Mike in forum General Bike Related
    Last Post: 09-13-06, 09:57 AM
  5. Heated Gear
    By KB in forum General Bike Related
    Last Post: 09-22-04, 07:43 AM
