Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 107
get a load of this crap
  1. #76
    I Dance With Will
    Oct 2002
    unknown
    Originally posted by SSearchVT
    Have you checked the throttle position sensor? Does it run worse the faster it spins (more rpm), or the more you open the throttle? It should be an easy test to measure the resistance with a multimeter.
    i have not. it lost power, slows down, the more i give it gas, open throttle, but smooth.
    "fuckit!"
  2. #77
    I Dance With Will
    Oct 2002
    unknown
    it feels like pressure is build up and no way out. i think
    "fuckit!"
  3. #78
    Waterbury, VT
    It's a long shot, but you're already into the engine pretty deep. It wouldn't hurt to check. Good Luck
    SSearchVT
  4. #79
    Just Registered
    Is it not obvious?
    do these bikes have any kind of manifold pressure sensor? airbox pressure? I would assume to make the best hp with the ram air they would...maybe something is awry with yours. Seeing as it seems to rev ok freely, but not when actually moving.
    will it get to 8k or is there something like a soft-limiter that is keeping you from reaching it? could be a neutral safety switch or something lame like that too.
    Oct 2001
    Bedford, MA
    Yes they do have MAP sensors AFAIK. Mine has one, I think most do as opposed to a MAF sensor due to size & complexity.
    But a failure in that sensor should trip the FI light, and then Kham should be able to read a code to figure out which sensor is bad.
    Dec 2003
    Ma
    When you're done ruining this bike I'll give you $200 for it.
  7. #82
    I Dance With Will
    Oct 2002
    unknown
    yea exactly. FI is not lit at all. the pressure sensor is under the back seat.
    what im think to do tonight is put some injector cleaner in, open the gas tank cap little bit and test ride without the pipe.
    "fuckit!"
  8. #83
    I Dance With Will
    Oct 2002
    unknown
    you sure you didn't forget the dot between the 2 and 0s? $2.00?
    "fuckit!"
  9. #84
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Did you check the butterfly valve in the header...like I said!!!!!?????
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
  10. #85
    I Dance With Will
    Oct 2002
    unknown
    no not the valve in header.
    I"M BACK IN BUSINESS YO!!! woohoo!!!
    "fuckit!"
  11. #86
    Just Registered
    Is it not obvious?
    you sold it to Jay?
    Just Registered
    Is it not obvious?
    I shouldn't post immediately after waking up...
    I Dance With Will
    Oct 2002
    unknown
    i'd sell it to Jay if it was a yamaha.
    i should mention ima got no diarrea ny more. yo!
    "fuckit!"
  14. #89
    Lifer Punjistick's Avatar
    Norwell, MA
    so what was wrong with it?
    I Dance With Will
    Oct 2002
    unknown
    wouldn't you like to know. i'll keep the suspense little longer. the answer is above actually. take a guess.
    "fuckit!"
  16. #91
    Norwell, MA
    some sort of sensor?
    Winchester, MA
    I'm guessing nobody gives a shit
    I Dance With Will
    Oct 2002
    unknown
    good guess. i'll send you a cookie. :
    on second thought i'll send you my diarrea
    "fuckit!"
  19. #94
  20. #95
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
  21. #96
    Norwell, MA
    perhaps some valve but not located in the header?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I assume this means its omething really lame and embarassing
    I suspect Law Enforcement HTDI
    Glen Beck is John the Baptist
  23. #98
    I Dance With Will
    Oct 2002
    unknown
    lame maybe but im not embarass. im glad i double check the timing, valve clearance, and the generator.
    what is missing here? and i don't expect Honcliffer to give a shit either. he can
    "fuckit!"
  24. #99
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    I'll take a guess and say the stock exhaust / catalytic converter was plugged.
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
  25. #100
    I Dance With Will
    Oct 2002
    unknown
    dink!
    now this would be a good reason to replace the crappy stock pipe.
    "fuckit!"
  1. Just blew my load
    By union in forum Pit Area
    Last Post: 02-22-09, 10:41 AM
