Damn that number is hard to chase down, I'm seeing references to it being 88db and 84db now... at 35mph. The 1198 at the very least closes the exhaust valve at that RPM range to pass the noise limit test, and lets it open at idle so it still sounds like a Duc.
The other thing to look at is the Euro II/III standards, as many bikes are designed to pass the stricter Euro III requirements now.
Don't thing so.
The AMA worked with SAE to develop a standard sound test.
The one test I saw for 82 dB was at 50 feet. The AMA got involved because many states an municipalities were developing their own arbitrary measurement specifications and noise levels.The SAE J2825 on-highway motorcycle sound test procedure is similar to the one used for the SAE J1287 off-highway motorcycle test. The streetbike measurement requires holding a calibrated sound meter at a 45-degree angle 20 inches from the exhaust pipe of a running engine. The procedure spells out how to do the test with the bike at idle, at a predetermined engine speed ("Set RPM Test"), or by slowly increasing the engine speed of the bike, known as the "Swept RPM Test."
The SAE J2825 standard, prepared by the SAE Motorcycle Technical Steering Committee, recommends a decibel limit of 92 dBA at idle for all machines or -- using the Set RPM or Swept RPM Test -- 100 dBA for three- or four-cylinder machines, and 96 dBA for bikes with fewer than three or more than four cylinders.
Yeah, but nothing says the SAE test is the EPA reg for getting exhaust approved on a production bike. I'll do some more digging later to pull up the exact requirements.
According to the AMA, the current MA law is: link
Maximum allowable A-weighted sound levels as measured from 50 feet (Chapter 90, Sec. 7T): 82dBA at 45mph or less; 86dBA over 45mph. Stationary noise levels: Motorcycles required to be registered for operation on the ways of the commonwealth shall not exceed the following noise levels when operated at 1/2 redline speed--99dBA manufactured after 1/1/86--102dBA manufactured before 1/1/86 (540 CMR 3:00)
DanG
- Blaise Pascal
