Results 1 to 25 of 47
R1 throttle mod
    R1 throttle mod
    read this on GSX-R forums about using an R1 throttle. I know it's a 1/5 turn as opposed to the stock 1/4 turn, but who here has done this on their bike?
    is it as quick and easy as it sounds, and was it worth it?
    Just Registered Doc's Avatar
    Jericho, VT
    Re: R1 throttle mod
    Gixxer's need some Respect?
    Re: R1 throttle mod
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: R1 throttle mod
    i just installed an R6 throttle tube on my SV650S, so it wouldn't be particularly surprising that the R6's bigger brother's tube fits the SV's older cousin....
    made a significant difference, and cleaned up a decent amount of throttle slop -- throttle blips are now telepathic and matching revs on the downshift is 99% smooth as perfection
    hurray, strikethrough!
    Re: R1 throttle mod
    thanks spicy. how much was the throttle & how long did it take to install? any other mods needed to make it work?
    Lifer Jayspeed's Avatar
    Medford, MA.
    Re: R1 throttle mod
    I looked into this when I had my 600. If I remember right, people were buying these from dealerships for like 12 bux. I remember it as being a cheap mod.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Reading-> 서올특별시 강남구
    Re: R1 throttle mod
    hahaha, i ordered mine from ronayers for a whopping $7.38, i believe. shipping took a while, but that's customary for RA -- cheaper for the product, but longer wait to get it (fine in the winter/off-season, but YMMV for when it's riding weather).
    no guarantees about whether or not it'll work on the gsxr, though. i'd try and find a write-up on one of the forums -- chances are if it can be done, there's instructions or a how-to guide somewhere online...
    the SV one was i think an 03 R6 tube that you had to cut a tiny tiny bit off, just so that the tube could return to closed throttle (otherwise it'd close to like 5 or 10%). just google canyonchasers and go to the workshop (for the SV one).
    after that, the install took 10min or so, from unscrewing the first screw to firing her up and seeing how she worked. my throttle cables had become a little stretched with the stock tube, so i didn't need to take off my fairings to add some length to the cable (which you may or may not need to do, if the swap is possible). i'm pretty noobish at doing mods, though, so if i can do it in that time, chances are you can too.
    i took the stock one off, lined up the two tubes, matched the tabs, and dremeled off probably 1/8" to ensure it would close all the way.
    Re: R1 throttle mod
    very helpful...thanks. i need to head to Brockton Cycles soon, so maybe I'll just buy a throttle from them
    Jericho, VT
    Re: R1 throttle mod
    The R is for respect....
    Re: R1 throttle mod
    Ok, well I should have asked about 1/5 turns instead of the stock 1/4 turn throttle
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: R1 throttle mod
    The best mod you can do to any suzuki is add yamaha parts!
    Re: R1 throttle mod
    Quote Originally Posted by l3uddha View Post
    i thought you don't go over 100mph
    tell me that's gunna change
    not for speed. i hear it makes the throttle response much smoother, and the obvious shorter turn improvement
    Re: R1 throttle mod
    you have a 1000 right?
    600
    Re: R1 throttle mod
    oh man... i thought yo were so much cooler...
    thanks.
    not going with a 1000 for a 1st bike. when people walk up and ask if my bike it a 1000, i usually tell them it's a 250
    Lifer R1's Avatar
    Re: R1 throttle mod
    Whats wrong with a 1000 as a first bike?
    Everybody i know is doing!
    Its the coolest!
    Re: R1 throttle mod
    A few points here:
    A 1/5 turn throttle will make the stop to stop distance on your throttle closer.
    What it won't do:
    It won't give you any smoother or faster acceleration.
    It won't smooth out a power curve or fix on-off throttle transition problems.
    It won't magically make your throttle cables less sloppy (that was pure chance and they must have been maladjusted before).
    If you feel that you have mastered the ability to fully control a throttle on corner exit (ratchet method) then by all means go to a 1/5 turn throttle. if you haven't got very good throttle control already, then a 1/5 turn throttle is a highside waiting to happen.
    Anyone tried a 1/6 turn throttle yet?
    Re: R1 throttle mod
    Quote Originally Posted by R1slowflyer View Post
    Its the coolest!
    so is peing your pants, right?
    before this gets , people who know me or have seen my new parts list, know that I'm not into making the bike faster. just want it to run better and smoother.
    Lifer R1's Avatar
    Re: R1 throttle mod
    If peing your pants is cool, consider me miles davis!
    slipper clutch?
    Re: R1 throttle mod
    answered my questions. Looks like the throttle mod isnt for me. thanks Degsy
    Foxboro, MA
    Re: R1 throttle mod
    you are a dirty bastard
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Lifer R1's Avatar
    Re: R1 throttle mod
    There is a company in england that makes a valve that acts as a slipper clutch give me a little bit and ill post it up. It supposedly uses the engine back pressure to eliminate the jerkyness of on and off throttle.
    Re: R1 throttle mod
    Keith, that might be something i'd be interested in. Degsy, ever hear of this one?
    Lifer R1's Avatar
    Re: R1 throttle mod
    https://www.harris-performance.com/w...System_77.html
    I cant find the review but apparently it works as designed it smooths out the on off throttle and actually allows the bike to burn cleaner, but the performance gains were not substantial when they tested it on an R1. If i could find the damn thread i would post it up, but i have tried to search and its gone. anyway they ran it on a dyno and tested it on the street and apparently it seems to do its job, but try and read more about it, I am still a bit skeptical.
    MCN did a review with a newer GSXR and the exhaust that goes with the system and it had significant power gains but i am sure that can be attributed to the exhaust
    hope that helps.
    BTW anyone here have any experience with this product?
    Re: R1 throttle mod
    hmm, ok thanks. i dont ride fast, so i dont care about the performance gains.
    Lifer R1's Avatar
    Re: R1 throttle mod
    Like i said the power gains were almost non existent with just the valve, it was the slipper clutch effect that made this a big topic, and from what ive read it did that well.
    If i had the money and time it would definately be my first and only mod to my bike. the only thing i dont like is the on off throttle response of the R1, kinda scary mid turn.
  1. whiskey throttle
    Last Post: 03-25-13, 05:51 PM
  2. Replies: 59
    Last Post: 12-24-11, 12:12 PM
  3. need a duc throttle..
    By landricscustoms in forum Wanted
    Last Post: 09-20-10, 11:07 AM
  4. Throttle bog at low RPM
    By The Snowman in forum Bike Maintenance
    Last Post: 08-23-07, 06:23 AM
  5. throttle mod?
    Last Post: 11-15-06, 11:36 AM
