heres a video on it!
Video: Harris performance total velocity range - Motorcycle News - MCN
yeah, i never said it would fix any throttle slop -- i might've articulated wrong, though. my cable was stretched before i did the swap, and when i made the adjustment, i deliberately cut off slightly less than i expected to need to, since i'm pretty sure my suzuki throttle tube wasn't meeting the return without a 1/8" of slop -- i don't think it was a cable issue, i'm pretty sure it was a less-than-perfect manufacturing process or something like that, the tolerances being much smaller on the R6 tube. just so happens that it fits.
i gotta run to a monster exam, though. grad-level psych of persuasion class that only has 2 exams, so each is worth 50% of my final grade![]()
hurray, strikethrough!
Gotcha. I thought you were saying that installing the 1/4 turn made the cable tighter and took away slack.
It does mean the cable will be tighter, but if it is properly adjusted now, it must have not been before.
Anyhoo, I know what you mean now.
As for the Harris performance vacuum thingy. That's a new one on me.
The only ways I know to cure a jerky low rev throttle are to install a power commander and remap the low end or to adjust the idle up to 2k or 2500rpm. not a solution for the street, but common for racers.
Yeah, why not just get a PC III and install a new map or get a custom map made.
Anyway what exactly is the problem you trying to fix?
Its like this whole thread is off topic without this important info!
2008 Honda CBR 600RR
Reducing the throttle rotation makes wot easier to achieve. Thats the only reason I'd do it. I doubt I'll need this mod on this bike.![]()
Jay
2013 gixxer 750
2009 Ducati M1100s
2017 KTM exc-f 350
alright well i did this mod and like others have said its cheap i think cost me like $13 from brockton cycle. took less than 15min to do and honestly i can feel the difference....its not a lot, but there is some. to me worth it cause it doesnt cost a lot and so why not do it?
1995 Mustang GT
12.60's @ 110(just motor)
2007 GSX-R600 Black/Matte Black
LOR two.six.zero slip on
Drivin 520 conversion Black w/ Silver RK chain
black/black Pazzo shorties
Zero Gravity DS wind screen
R1 throttle tube
powdercoated satin black rearsets, passenger pegs, etc.
custom fender elim. w/custom led lights
mtec high/low beams bulbs w/ white led parking lights
http://www.cardomain.com/ride/701293
I'm just replacing my throttle on the GS with an on/off switch. Partial throttle is for wimps.
I thought I'd chime in hear with all of this commotion. I believe this mod originated from an article in Sport Rider...
The FX Project Part 1 - Sportbike Review - Sport Rider
My BS alarm went off approximately 50 seconds into the video when the salesman claimed that the pipe produced all these gains without a need to remap. 2 minutes later the claims that just the vacuum device added 10hp and cut emissions by 40% to 60% re-triggered the alarm. At 6:30 seconds, the claim is 15hp gained with the exhaust and intech gizzy, all without a remap. At this point the alarm pegged WFO.
the ppower gains weren't even what interested me the most, more the actions of the slipper clutch. the only reason i posted it here DB was looking for smooth on off throttle, from what i know it can be solved with a better technique or a slipper clutch, and for the money this seemed like a reasonable option if it indeed works! i posted the video to show the slipper clutch effect. and with just the vacuum installed it looked to work, but without actually getting to test it for yourself you'll never know, and yes the power gains do seem rediculous especially how they "didn't hit record on the camera", but engineering is a funny thing, sometimes it works!
