Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
R1 throttle mod
    Lifer R1's Avatar
    Somewhere you dont know...
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: R1 throttle mod
    yeah, i never said it would fix any throttle slop -- i might've articulated wrong, though. my cable was stretched before i did the swap, and when i made the adjustment, i deliberately cut off slightly less than i expected to need to, since i'm pretty sure my suzuki throttle tube wasn't meeting the return without a 1/8" of slop -- i don't think it was a cable issue, i'm pretty sure it was a less-than-perfect manufacturing process or something like that, the tolerances being much smaller on the R6 tube. just so happens that it fits.
    i gotta run to a monster exam, though. grad-level psych of persuasion class that only has 2 exams, so each is worth 50% of my final grade
    hurray, strikethrough!
    Re: R1 throttle mod
    Quote Originally Posted by spicy View Post
    Gotcha. I thought you were saying that installing the 1/4 turn made the cable tighter and took away slack.
    It does mean the cable will be tighter, but if it is properly adjusted now, it must have not been before.
    Anyhoo, I know what you mean now.
    As for the Harris performance vacuum thingy. That's a new one on me.
    The only ways I know to cure a jerky low rev throttle are to install a power commander and remap the low end or to adjust the idle up to 2k or 2500rpm. not a solution for the street, but common for racers.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Re: R1 throttle mod
    Yeah, why not just get a PC III and install a new map or get a custom map made.
    Anyway what exactly is the problem you trying to fix?
    Its like this whole thread is off topic without this important info!
    2008 Honda CBR 600RR
    Re: R1 throttle mod
    Actually, in my experience, a quick turn throttle can mask on/off abruptness (at least on a carbed bike). Don't know why exactly, but it felt that way on my duc...
    Re: R1 throttle mod
    because the cam has a larger circumference, it automatically takes slack out of throttle cables. That's probably why.
    Re: R1 throttle mod
    Quote Originally Posted by akira700 View Post
    making it smoother when getting off the throttle. basically, just looking into things to make the bike ride and run better.
    Lifer Jayspeed's Avatar
    Medford, MA.
    Re: R1 throttle mod
    Reducing the throttle rotation makes wot easier to achieve. Thats the only reason I'd do it. I doubt I'll need this mod on this bike.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    May 2007
    Re: R1 throttle mod
    alright well i did this mod and like others have said its cheap i think cost me like $13 from brockton cycle. took less than 15min to do and honestly i can feel the difference....its not a lot, but there is some. to me worth it cause it doesnt cost a lot and so why not do it?
    1995 Mustang GT
    12.60's @ 110(just motor)
    2007 GSX-R600 Black/Matte Black
    LOR two.six.zero slip on
    Drivin 520 conversion Black w/ Silver RK chain
    black/black Pazzo shorties
    Zero Gravity DS wind screen
    R1 throttle tube
    powdercoated satin black rearsets, passenger pegs, etc.
    custom fender elim. w/custom led lights
    mtec high/low beams bulbs w/ white led parking lights
    http://www.cardomain.com/ride/701293
    Re: R1 throttle mod
    seems more of a common mod on the GSX-Rs than other street bikes.
    Re: R1 throttle mod
    I dont think i'll need it on my bike since it's street only. but for $13, I will probably install it before selling my bike. it sounds more of a custom performance upgrade for people that dont know bikes.
    Re: R1 throttle mod
    A few points here:
    A 1/5 turn throttle will make the stop to stop distance on your throttle closer.
    What it won't do:
    It won't give you any smoother or faster acceleration.
    It won't smooth out a power curve or fix on-off throttle transition problems.
    It won't magically make your throttle cables less sloppy (that was pure chance and they must have been maladjusted before).
    If you feel that you have mastered the ability to fully control a throttle on corner exit (ratchet method) then by all means go to a 1/5 turn throttle. if you haven't got very good throttle control already, then a 1/5 turn throttle is a highside waiting to happen.
    Anyone tried a 1/6 turn throttle yet?
    Re: R1 throttle mod
    Quote Originally Posted by l3uddha View Post
    just makes it easier to get to wide open, which can be a bad thing in the wrong hands.
    like yours?
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: R1 throttle mod
    just ride it...if you are itching to do anything get a new shock and revalve/spring your forks....
    Re: R1 throttle mod
    Re: R1 throttle mod
    I'm just replacing my throttle on the GS with an on/off switch. Partial throttle is for wimps.
    Posting Freak senecak19's Avatar
    Massachusetts
    Re: R1 throttle mod
    I thought I'd chime in hear with all of this commotion. I believe this mod originated from an article in Sport Rider...
    The FX Project Part 1 - Sportbike Review - Sport Rider
    Lifer Pittenger5's Avatar
    Austin
    Re: R1 throttle mod
    That aint a bad idea, Im not sure its possible to high side those things. Im looking into it for my EX.
    Zip Tie Alley #505
    Re: R1 throttle mod
    Quote Originally Posted by R1slowflyer View Post
    My BS alarm went off approximately 50 seconds into the video when the salesman claimed that the pipe produced all these gains without a need to remap. 2 minutes later the claims that just the vacuum device added 10hp and cut emissions by 40% to 60% re-triggered the alarm. At 6:30 seconds, the claim is 15hp gained with the exhaust and intech gizzy, all without a remap. At this point the alarm pegged WFO.
    Lifer R1's Avatar
    Re: R1 throttle mod
    the ppower gains weren't even what interested me the most, more the actions of the slipper clutch. the only reason i posted it here DB was looking for smooth on off throttle, from what i know it can be solved with a better technique or a slipper clutch, and for the money this seemed like a reasonable option if it indeed works! i posted the video to show the slipper clutch effect. and with just the vacuum installed it looked to work, but without actually getting to test it for yourself you'll never know, and yes the power gains do seem rediculous especially how they "didn't hit record on the camera", but engineering is a funny thing, sometimes it works!
  21. #46
    Re: R1 throttle mod
    Shit, if the brakes on the EX actually slowed the bike down I'd never turn the throttle off.
  22. #47
    Austin
    Re: R1 throttle mod
    You just need some stickier sneakers or better yet, cleats, and fred flintstone the hell out of that bike.
    Zip Tie Alley #505
  1. whiskey throttle
    Last Post: 03-25-13, 05:51 PM
  2. Replies: 59
    Last Post: 12-24-11, 12:12 PM
  3. need a duc throttle..
    By landricscustoms in forum Wanted
    Last Post: 09-20-10, 11:07 AM
  4. Throttle bog at low RPM
    By The Snowman in forum Bike Maintenance
    Last Post: 08-23-07, 06:23 AM
  5. throttle mod?
    Last Post: 11-15-06, 11:36 AM
