Page 1 of 5 12345 LastLast
Results 1 to 25 of 101
Where do you shift?
    Member deeto's Avatar
    Sep 2006
    Medford, MA
    Where do you shift?
    I messed around with a lot of shift points this past year trying to find what felt most comfortable and was the fastest.
    Where do you shift? Use the template to draw it up. Make sure you mention your bike and gearing setup:
    spes sibi quisque
    LRRS AM #511 (retired)
    DNF Racing
    Sep 2006
    Medford, MA
    mine
    bike: 06 R6
    gearing: stock
    This was what I ran for most of last season.
    I don't think I like running turn 1 and the whole back half of the track in 2nd, so I'm going to try this in April. Might have to up the rear sprocket a few teeth though:
    spes sibi quisque
    DNF Racing
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    Where do you shift?
    You should drop a tooth in front and add 2 in the rear. Stock gearing is to much for this track.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Where do you shift?
    This is how I run it.
    88 Honda Hawk
    Stock gearing (16/44)
    Boston --> San Diego
    Where do you shift?
    i'm a little slow comin outta 6 and 10..... but if I carry good cornerspeed it'll work.
    Gonna try some other things w/ gearing & dial it in.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Where do you shift?
    a 6300 RPM rev limiter and HD gear ratios made for some funky shift points....oh yeah my ineptitude may have something to do with that as well.
    i haven't worked out all my shift points on the NSR after just one weekend but i can say there sure is going to be alot more of them.
    Where do you shift?
    I know the number of shifts is right... but they all might be one gear higher?
    Honda 600rr -1 in front, +1 in back from stock
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    If I had a clue of how to use paint or some shit I'd like to work that up.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Where do you shift?
    This is a great thread. Getting shift points is the first step in going faster/riding more consistently. You really can't use other peoples shift patterns unless you have the same bike and gearing, but it's critical to have YOUR shift points clear in your head before you make other changes to your riding.
    Here's a busy lap!
    This is a qualifying lap. If racing in traffic I have a few more shifts!
    edit: Oh yeah, in case you didn't figure it out I'm on a 125 15/38 ( at least I think it's a 15, could be 14 can't remember)
    Lifer legalspeed's Avatar
    Somersworth, NH
    Where do you shift?
    Getting out of 2nd from 6-12 would be nice, do what Kip says.
    LRRS\CCS\WERA #486
    Dec 2003
    Ma
    Where do you shift?
    '03 CBR 600RR
    think my gearing is currently 15 - 45 or 44
    I change shift points depending on what gearing I'm running and I've been playing around to get myself the right setup lately.
    And this track map looks like tight ten configuration to me.
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Where do you shift?
    Here's mine:
    05 ZX636, stock gearing
    I also estimated mph from my speedo (and memory)
    Look below for attachment
    Sep 2001
    Western MA
    Where do you shift?
    Here's another, this time on my MZ Scorpion 660. Single, 48 hp
    One thing that is important to understand is that one person's gear changes will differ from another simply becasue of pace. The same bike doing a 1:27 will have different gear shifts than someone doing a 1:23.
    For instance, IT takes more entry speed into turn 6 to allow carrying a taller gear all the way to turn 8 on the MZ.
    Sep 2001
    Western MA
    Where do you shift?
    Here's the ZX6 map:
    Nov 2002
    Cranston ,RI
    Where do you shift?
    I agree with what Paul said. One thing I found that helped me when I first started out was doing less shifting and concentrating more on corner speed.
    With that being said I'm sure everyone wants to know where the Woods shift at. I have followed them around in practice so I have a good idea where they shift and I think Jeff's gearing is a 15/49 on his GSXR 600.
    T 1 - Down shift 2 gears and hold gear thru T 2. Up shift a gear coming out of T 2 and hold to T 3. Down shift a gear going into T 3. Up shift a gear at T 4 and hold that gear thru T 5. Down shift a gear going into T 6. Up shift a gear between T 6 & 7 and hold that gear thru T 8. Down shift a gear going into T 9 and hold that gear until T 11. Down shift a gear going into T 11 and hold that gear thru T 12.
    The only part I might be off is Jeff might up shift 2 gears coming out of T 2 and then down shift 2 gearing going into T 3.
    Where do you shift?
    Someone wanna paint this up?
    Nov 2002
    Cranston ,RI
    Where do you shift?
    If I had a clue how to use a computer I would.
    Where do you shift?
    *start
    *programs
    *accessories
    *paint
    .... if you can't use MSPaint you should bring your computer to a 4 year old... they can teach you.
    Where do you shift?
    kawi 636 15/47
    Where do you shift?
    This is for the super retard CRF450 15/39
    Nov 2002
    Cranston ,RI
    Where do you shift?
    Originally posted by OreoGitorio
    *start
    *programs
    *accessories
    *paint
    My daughter is 4 let me ask her how to do it.
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    YAY now I don't have to go ask my nephew who's 9 how to use mspaint. Mike that is spot on for the crf450. I'm running the X model and the gears are a little taller I'm running a 42 out back but still spot on for shift points and gears. Now if I could only go as fast as you!!!
    I'm happy I ripped a 28 off on the last weekend. I only had 3 weekends the last three and two of them were wet and cold. I got a 3rd place wood in super singles the last race of the season. I was glad a lot of people went home early.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2003
    Ma
    Where do you shift?
    kawi 636 15/47
    I think that's what I'm looking to run for gearing and shift points this upcoming season. Either 15 - 47 or 15 - 48 on my stock motor 03 600RR. See how it works out in practice.
    Where do you shift?
    Jay, most of the guys running Hondas are using a 48. The only problem you gotta watch for is chain length/tire clearance. With the 48, if you try to keep the wheel as far forward as possible, the tire will rub on the shock linkage. It also depends on the tire manufacturer too. Just pay attention when you put it together.
    Dec 2003
    Ma
    Where do you shift?
    Yup, I'll probably add a link in the chain. The bike Sheesher (sp) sold to nazo had the rear tire touching the dogbones and he was geared at 14 - 43 I think. Running bone stock against the new bikes I definitly need a little more pull at the rear.
  1. Broken Shift rod
    By ducatirdr in forum Pit Area
    Last Post: 04-17-17, 01:33 PM
  2. GP Shift
    By Petorius in forum Pit Area
    Last Post: 09-18-15, 11:17 PM
  3. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  4. GP shift?
    By Awesome in forum Pit Area
    Last Post: 05-05-05, 05:07 PM
  5. GP Shift
    By snaggle in forum Bike Maintenance
    Last Post: 07-18-04, 12:30 AM
