Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 101
Where do you shift?
    Where do you shift?
    Originally posted by rmbbikes
    YAY now I don't have to go ask my nephew who's 9 how to use mspaint. Mike that is spot on for the crf450. I'm running the X model and the gears are a little taller I'm running a 42 out back but still spot on for shift points and gears. Now if I could only go as fast as you!!!
    I'm happy I ripped a 28 off on the last weekend. I only had 3 weekends the last three and two of them were wet and cold. I got a 3rd place wood in super singles the last race of the season. I was glad a lot of people went home early.
    He He, you said wood!! Anything under a 30 is a good pace for a motard. Especially if it was your first dry weekend. It took me a weekend or two to get used to the motard. JUST KEEP RIDING!!!
    Where do you shift?
    i think this is right. the "template" is actually for "tight 10" so i improvised.
    im riding an 01 SV650 1 tooth down in the front. best time: low 1:21 sometimes 1 run 4th gear through 1 and down to 3rd for 1a and 2. its pretty rare that hit 6th unless im trying to pass down the straight
    Member deeto's Avatar
    Sep 2006
    Medford, MA
    Where do you shift?
    what gear is the beige color?
    spes sibi quisque
    LRRS AM #511 (retired)
    DNF Racing
    ....... Nazo's Avatar
    Jul 2004
    Where do you shift?
    Those are his sections of missed shifts, thats why he's slow
    Chris
    LRRS Expert #160
    Where do you shift?
    what beige? there is no beige! 3rd gear is yellow.. maybe the key in the corner you cant see that..oh and Nazo....
    Sep 2006
    Medford, MA
    Where do you shift?
    yea I can see the key
    please don't tell me I'm going colorblind
    spes sibi quisque
    DNF Racing
    Where do you shift?
    that's not beige, it's fuckin dull yellow.
    Where do you shift?
    What? You don't use your 2.5 gear?
    It's a critical part of going fast.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Where do you shift?
    i dont know why it "might" be a shade different i used the same color.
    would you like me to redo it? will that shut you up? i was trying to help and all i get from you is a hard time! are you sure your name isnt Heath Smith?
    Where do you shift?
    ill just tell you when i pass you
    <-- for 2nd gear and one for 1st
    Where do you shift?
    Sep 2006
    Medford, MA
    Where do you shift?
    what are running for sprockets? theres no way ill ever see 6th on the front straight
    spes sibi quisque
    DNF Racing
    Where do you shift?
    i dont know. its an 01 SV650S with one down on the front. 14/44 maybe? i dont know. i do know that its the OEM rear sprocket and the OEM clutch and until the last race weekend it was OEM suspension
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    Originally posted by mmracer37
    This is for the super retard CRF450 15/39
    Mike a few ?'s for you for next season. When you're on the 450
    Knee down or foot out?
    Where do you brake going into 3? Do you bang all three gears with the clutch in and on the brakes and then let it out or do you down shift one let the clutch out, then another and let the clutch out, then another let the clutch out?
    5th gear round 9 and 10 and then 2 gears in the braking zone in between 11 and 11a where the puddle usually gathers, while you're straight up and down?
    Gracias!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Where do you shift?
    I'm not Mike, but if you're straight up and down where the puddle is you be slow! That's a corner, not a straight!
    It takes a long time to get there, but it's knee down territory...
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Where do you shift?
    wait, that's supposed to be a corner? damn, i am slow.
    Dec 2003
    Ma
    Where do you shift?
    Yup, my proggression was from kicking the bike straight up and down there to knee down coming in, staying off the bike and kicking it up a bit and braking, and my newest level is trail braking it lightly instead of putting a kill on it. Also depends if I'm dropping a gear when I come in or not. The plan is to be knee down through and through.
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Where do you shift?
    Goddamnit. I shift EVERYWHERE on that damn 'tard. I'm probrobly doing something wrong...
    Where do you shift?
    Gracias!!
    Usually in NH it's knee down (unless I'm goofing off )
    I get on the brakes into 3 right about half way (3rd cone) down the chute. I NEVER touch my clutch lever during a race, just kick it down. However, I have a slipper clutch in my bike (makes life easy).
    I'm in 4th going thru 9&10, then I grab 3rd going into 11 .
    Hope this helps
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    Thanks Mike
    LRRS/CCS EX #13
    GMD COMPUTRACK
  21. #46
    Jul 2003
    Bozeman, MT
    Where do you shift?
    Mike,
    NIce meeting you on Wensday! Thanks for hosting that seminar.
    Can you downshift like that using say... 1/8th clutch on a non-slipper-equipped tard without fear of transmission damage?
    People keep telling me you can, but I'm leery of stomping hard on that shift lever without the clutch engaged. I dont care if it starts hopping the back around, I can control that with light clutch control, but I dont want to bend shift forks.
  22. #47
    Where do you shift?
    if you use a little throttle when stomping down it'll relieve the pressure on the tranny & pop into the next gear easier... i downshift my EX w/o the clutch 90% of the time.... Hit the brakes, put pressure on the lever, blip the throttle like you're rev matching & it pops right in
  23. #48
    Jul 2003
    Bozeman, MT
    Where do you shift?
    Hmmm.. Thanks Pete! Something else to try. Never downshifted (except by accident) without the clutch.
    I guess my fear would be that it wouldnt engage, and I'd be halfway into T3 in 4th gear, and off-roading in the kitty litter.
  24. #49
    Where do you shift?
    it's just like upshifting w/o the clutch... just gotta relieve tension on the trans.
    I should add that if you get it right it's butter smooth... if you don't, it's a little jerky.... because of that I use the clutch if i'm leaned over.
    PS... others will tell you it increases wear to the transmission... i haven't seen that yet, nor do i really even care if it does
  25. #50
    Where do you shift?
    Originally posted by rebelpacket
    Mike,
    Just what Pete said!!!
  1. Broken Shift rod
    By ducatirdr in forum Pit Area
    Last Post: 04-17-17, 01:33 PM
  2. GP Shift
    By Petorius in forum Pit Area
    Last Post: 09-18-15, 11:17 PM
  3. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  4. GP shift?
    By Awesome in forum Pit Area
    Last Post: 05-05-05, 05:07 PM
  5. GP Shift
    By snaggle in forum Bike Maintenance
    Last Post: 07-18-04, 12:30 AM
