Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Top SV 650 Lap Times at LRRS
    Member bdawkins20's Avatar
    Cape Cod Ma
    Im just curious as to what are the best lap times a basically stock SV 1st Gen has run at LRRS. Nothing greater done to the motor except say-pipe,filter,and jet kit. I have no Idea of what Ricky D has done to his bikes and I believe Oreo is pretty much stock for his 2nd gen with no major work done. I would figure if you touch a 1:19.999 on a basically stock SV you are pretty damn fast.
    AM#220
    99 cbr 900 street
    02 sv 650 race
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: Top SV 650 Lap Times at LRRS
    Oreo is well into the 17s on a more or less stock bike. Not sure but he may have been into the 16s...
    Dude is damn fast.
    I'm happy running a stock motor in the mid 19s.. Although I figure 18s are in the cards this year. Certainly 17s are doable on a stock motor with some suspension work. You are not getting there without suspension work in my book. Unless you're some sort of freak!!
    Doucette does 15's, but nit sure if that's in his SS or SB bike.
    Doucette's best on an SV is actually 1:14.9something on the SuperBike, I believe.
    He has run high 15's on. The SS bike though.
    Hiram, ME
    When I was researching for the threshold to advance to EX, the fastest lap I could find for Doucette in LWSS was a 1:16.834. I only went as far back as the latest track change, and I could have missed something.
    Hiram, ME
    My fastest on stock forks with emulators was 22.0. Changing to cartridge forks brought me to 21.0 in a weekend, but I attribute that to added confidence. Anyone recall what times were up front in the MWPT class when it was around? Those were stock bikes!
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Ricky did a 17.273 in MWPT in 2011 and Mark Dages did 17s also.
    Hiram, ME
    There ya go. 17's on a basically stock SV. Proof positive that the rest of us suck.
    Vero Beach, FL
    1.18.0 was as fast as i could get one but others have gotten a couple more seconds. Jeff wood got one into the high 12's but i think it was built to the hilt
    Hiram, ME
    Speaking of Jeff Wood...there was a grey 2nd gen SV over in the Penguin garage last Friday, sporting white plates with a black "9" on them...
    Lifer lrrs313's Avatar
    Asheville, NC
    J Wood is not human at NHMS. Didn't he take an ex500 out a few years back and do some crazy lap time?
    -Brian
    15 S-Works Venge
    Rocky Hill, CT
    It makes me sad that some people can go faster on their stock bikes than I can on a superbike
    Bridgewater, MA
    it makes me sad that Jeff could probably lap faster on a Schwinn than I can on my racebike
    Quote Originally Posted by bdawkins20 View Post
    Put Jeff Wood on a 100% completely showroom stock bike and with the right tires I bet he could get it into the 16's pretty quickly.
    As far as current LRRS racers, Ricky could probably get one into the low 17's easy enough.
    EDIT: MWPT post above confirms.
    Bet I could get one into the 19's........ maybe 18's, but that's probably pushing it.
    Quote Originally Posted by lrrs313 View Post
    17.9 I believe. Maybe 17.7? Think it was one of Data Temple's PTwins bikes.
    In fairness, MWPT rules were basically LWSS rules but with a stock exhaust.
    Wirelessly posted (GS3)
    I've done 18s on mine.
    Slicks
    Gsxr front end with a penske shock in the back
    The engine has the usual (pipe, jet kit, airfilter) and the can swap. It also has 60k+ on the engine.
    My set up with a fresh engine should be able to get me into the 17s or even 16s. 14s with some motor work. This is all assuming I had any talent.
    Cape Cod Ma
    So to take this a little further .........do you guys think that when you get a stock sv into the teens (17-18) that you, at that point- "reached the capabilities of that machine"
    Its tough to think about but my best is a 1:23.7 and I can't fathom knocking say 4 sec off....in fact I am going backwards. Hats off to you guys for showing guys like me that it is possible. I was talking with some fellow amateurs last event and it really is something else to see you guys doing what you are with what you have.
    And where the hell is Jeff Wood btw???????
    AM#220
    99 cbr 900 street
    02 sv 650 race
    We're talking about 22's on stock forks, and faster with a gsxr front end? I'm a sv noob.
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    I did a couple 20's and some 21's on an sv with emulators and a Penske. Stock motor and stock exhaust.
    Apr 2011
    NH
    1:19 on an SV is moving.
    Seth H. hit a 15.9 last weekend in Thunderbike on a basically stock SV. old stock motor, the suspension is set up for him but nothing crazy, no GSX-R forks not sure about the internals.
    I second Painfullyslow(which, by the way, your name no longer make sense) it is sad when a bike/rider with much less power are way faster. Something to shoot for though.
    Tim
    LRRS #44
    Superbike Services 44
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Slightly off topic. But what is an average lap time difference bwtween the same rider on an ssSV vs a MWSS at NHMS?
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    3-4 seconds?
    With Mike, he has a set of SV forks w/ cartridges in them, instead of the stock damper rod setup. Stock triples.
    Quote Originally Posted by timmyho414 View Post
    I thought Hahn's bike was built pretty severely. He definitely runs that thing on the edge.
    With Mike, he has a set of SV forks w/ cartridges in them, instead of the stock damper rod setup. Stock triples.I thought Hahn's bike was built pretty severely. He definitely runs that thing on the edge.
    Mikes avatar looks like it has a gsxr front end. No?
    Knowing he's the mad scientist type, why would he build a sb without it?
    Or a different mike?
    Michael's (Painfully Slow) avatar is GSXR forks, but it was Mike Kurtz that said he did 22's on stock forks and 21's with cartridges.
    I hit 19's last year with stock lower fork legs (uppers were from a ZX-6R) & GMD-worked cartridges and stock triples.
    I have since converted to a GSXR front end and R6 radial calipers.
  1. Replies: 8
    Last Post: 11-13-12, 11:08 PM
  2. lap times dropped
    By sprinkler_1 in forum Penguin School
    Last Post: 10-08-12, 05:44 PM
  3. LRRS preEntry times 2012
    By xsiliconkid in forum Pit Area
    Last Post: 08-08-12, 01:19 PM
  4. Get your Daytona Lap Times
    By nt650hawk in forum Pit Area
    Last Post: 01-26-09, 08:34 PM
  5. Just how many times....
    By R7 in forum Dirty Bastards
    Last Post: 07-23-06, 07:47 PM
