Results 1 to 7 of 7
Changing fork oil
    Winchester, MA
    Changing fork oil
    I'm going to be yanking the forks to change the oil soon on my 98 zx6r, as I don't believe the oil has ever been changed. Is there anything else I should be doing while I have the forks off? I might do the fork seals just as a matter of preventative maintenance. Any other wear parts in there?
    Lifer odduc's Avatar
    NH
    Changing fork oil
    You definitely will want to do new seals. They're an inexpensive preventative maintenece item. Besides, the old seals might get a little bit roughed up when removing. Be very careful not to scrape too much metal off of the fork legs. It can be a frustrating job, so take your time. I would highly reccommend you have a service manual.
    I'll be doing mine on the FZR, this weekend as well as adding new, stiffer springs.
    LRRS#167
    Winchester, MA
    Changing fork oil
    thanks mang, I will take your advice and do the fork seals while I'm in there. I hear it can be a bitch of a job, but I got a vice, and tools, and a service manual, hopefully it goes according to plan.
    Was considering springs/valves but I'm not sure if I'd notice the difference, I'm about 170 and I think that's in the sweet spot for the stock setup if I'm not mistaken
    May 2003
    Lakes Region, NH
    Changing fork oil
    and when in doubt...follow Bryan's lead and use a bigger wrench
    Bras cause cancer.
    NH
    Changing fork oil
    Good luck with it.
    LRRS#167
    Gone Fishin' trackdog's Avatar
    Changing fork oil
    [QUOTE]Originally posted by Nikon
    [B]and when in doubt...follow Bryan's lead and use a bigger wrench
    Nice Will......
    I still love the smell of burnt racing fuel in the morning!
    Raymond NH
    Changing fork oil
    At 35,000 miles and three oil changes, I'm still on the original seals on my 9R. I would not change the seals unless they leak. It's not a hard job to do though. Seals are simple devices and you can make a seal driver out of PVC pipe.
  1. changing fork seals...how do i...?
    By JonT in forum Bike Maintenance
    Last Post: 03-30-12, 02:16 PM
  2. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  3. changing fork seals on xr80
    By solgirl in forum Bike Maintenance
    Last Post: 10-05-10, 09:23 AM
  4. Changing a fork seal/fork oil??
    Last Post: 08-11-10, 07:58 AM
  5. Changing Fork Seals on my F4i
    By bmrider in forum Bike Maintenance
    Last Post: 09-19-08, 07:39 AM
