Page 20 of 22 FirstFirst ... 10111213141516171819202122 LastLast
Results 476 to 500 of 527
Harbor Freight tools that DON'T suck
  1. #476
    Re: Harbor Freight tools that DON'T suck
    Made it to 70 foot-pounds but snapped on its way up to 92.
    Harbor Freight tools that DON'T suck-pxl_20250323_150514683-2-jpg
    Harbor Freight tools that DON'T suck-pxl_20250323_150720388-2-jpg
    Go fast. Have fun. Repeat.
  2. #477
    Quote Originally Posted by dontpanic View Post
    what's the process of getting a replacement under lifetime warranty ?
  3. #478
    I don't know what HF's process is.
    *My* process will be to buy a replacement from somewhere else.
    That was the 8mm, BTW.
  4. #479
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    The right choice because the direct replacement would be made the same way and in the same place. That didn't work the first time, so try something else.
    Problem is that so many brands are now made "overseas", and good USA or Germany tools are getting harder to source.
    Mayhew is still made in western MA, as far as I know. For tools like that they may not have them, so I like Wiha and Wera products for hex, Torx, and Torx Plus drivers.
  5. #480
    8mm allen, 90ft/lbs?! What's the bolt/application?
    zoomed in and looked closer, what are those dark spots on the break ? defects? cracks?
  7. #482
    holland ma.
    That's what I'm saying. That's crazy numbers for that tiny screw. Max torque for a grade 8 8mm bolt is like 30ft\lbs . I wouldn't blame the tool for failing at nearly double that. I'm surprised the bolt didn't snap. Even grade 12 bolts are like 50ftlbs.
    I’ve used the auger a few times for fence posts and it makes the job much easier.
  9. #484
    Closer detail:
    Harbor Freight tools that DON'T suck-pxl_20250323_192530279-1-jpg
    Glad we're having this conversation. Discovered operator error.
    The application is the rear axle nut on a ZX1000. My bendy-bar deflection torque wrench only goes to 60 nm, so I went and got my clicker. I re-checked the specs, and thought I read 98 foot-pounds. The spec is 98 Newton meters, which is 72 foot-pounds.
    Ooops.
    The snapped hex probably saved me from a very, very large repair expense.
  10. #485
    holland ma.
    I'm still confused. The pinch bolt which I assume is what you are tightening is 64nm or 50ftlbs. Much more reasonable for an 8mm socket. 98nm is the nut itself.
    an 8mm socket drives a small nut, this tool is an 8mm allen, for a much larger fastener
  12. #487
    Haverhill, MA
    8mm hex key likely to be an M10 bolt
    Hypertarded
    RI / CT border
    I haven't experienced a failure like yours, however i'm guessing subliminally it's the reason why, when possible, i've switched to "impact rated" bits when purchasing from HF. no proof, but assuming would be stronger than the standard Pittsburg.
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    This screw extractor set is $30 in store today only. I think I'm gonna pick it up: https://www.harborfreight.com/multis...ece-58699.html
    I get those emails too. I may stop by and grab one meself...
  16. #491
    This guy does a lot of tool reviews. He’s found the supplier for a lot of HF tools.
  17. #492
    HF is out of my way, nearest is in Gilford or Concord, but since I retired, just don't travel in those directions
  18. #493
    Yeah...never made it.
    Okay? Where you planning on picking up a tool that doesn't suck from Harbor Freight though?
  19. #494
    Closer detail:
    Ooops.
    I had the opposite experience once.
    I was tightening a camshaft retainer bolt inside the cylinder head of my friend's Subaru.
    He looks up the torque spec & tells me "12 foot pounds".
    I get it up to 9 and it stops going any higher....
    I ask him to read the spec again...
    "12 foot lbs"...
    I turn it some more and it doesn't go higher...
    I ask him again...
    "12 ft lbs"....
    I turn more... still nothing... I look at him, he looks at me... okay... I go 1/100th of a turn further... *SNAP*!!!...
    I look at him, looks back at the spec....
    "*SIGH*... inch pounds".
    Aaaaaaaad OFF TO THE MACHINE SHOP IT WENT!
  20. #495
    Dublin, NH
    My KTM manuals list all torque values in Nm and ft-lbs, which is really annoying when you are dealing with lots of M5 and M6 bolts. Why can't you just list small fasteners in in-lb??
    I would use Nm but my torque wrenches all have decimal Nm values on them including the increment on the twist handle, so it's equally time consuming to use Nm as it is to just convert ft-lbs to in-lbs.
    2023 KTM 890 Adventure R
  21. #496
    Aug 2012
    LA
    Went to HF to swap out a busted cheapo torque wrench and an Icon speed collar impact extension; I use both to swap wheels on my mini toy hauler I keep in a storage unit. Was a quick swap with no money out of pocket so even if the tools don't last, the lifetime warranty thing is nice and easy.
    I picked it up but haven't used it yet. My take is that for $30 this is a high quality extractor set backed by lifetime warranty. I'll have to report back, hopefully I can use it this weekend.
    only tool I have from HF is my farm jack I ordered online last year, used it a couple times to lift logs
    https://www.harborfreight.com/60-in-...ack-58448.html
  23. #498
    South Coast MAsshole
    just got one of these plastic creepers from the new HF they put in my town not long ago...still have my old wood creeper with metal casters as well...now when my 7yo daughter helps me do oil changes on the car we both have one...also rolls much nicer, has handles, has a little recessed area for tools and screws, the head pad is cleaner...hoping it lasts
    https://www.harborfreight.com/300-lb...ray-63372.html
    Point37s Garage Sale Thread
  24. #499
    Lifer ZX-12R's Avatar
    Candia, NH
    I bought a blue one of those around Christmas when it was discounted pretty heavily to replace my old Craftsman creeper that had an MDF board as support which split a long time ago making it a pain to use. It's been working great despite me being a little over its stated capacity. As far as the head pad being cleaner, mine was until I was draining oil out of one of our vehicles and it burped out a bubble that sprayed the side of my face and got the pad!
  25. #500
    TWINS! xrocket21's Avatar
    Central Maine
    Old chunk of cardboard crew
  1. Harbor Freight Tools road trip.
    Last Post: 04-06-10, 07:46 AM
  2. Harbor Freight Tools
    By 2OO6rr in forum Business & Product Reviews
    Last Post: 06-21-09, 10:34 AM
