Results 1 to 14 of 14
Woodcraft rearset installation
    Jul 2006
    Hollis, NH
    I'm installing new Woodcraft rear sets on my 06 GSX-R750 and have a couple extra parts to deal with on the brake side. Two springs and a brake light switch. One spring used to attach to a peg on the OEM rearset and then to the brake light switch and the other spring was probably for brake pedal return. Do I discard the return spring and is there anything I can do to get my brake light switch functional?
    Worcester, MA
    The springs are trash. I suppose you could figure something out for the pedal return spring but its probably not worth the time. As far as getting your brake light working, you can buy a pressure sensitive banjo bolt. basically its a banjo bolt with wire coming off it that you plug into your wiring harness connection. hopefully someone will post a link for you. its out there.
    LRRS EX #165 (formerly)
    .... duey's Avatar
    Wilmington MA
    2021 Ducati Panigale V2
    2020 Honda Grom
    Worcester, MA
    thatll work.
    .... duey's Avatar
    Wilmington MA
    oh btw forgot to mention that i'm not sure if that is the right thread pitch. So double check that before ordering.
    2020 Honda Grom
    Jul 2006
    Hollis, NH
    Quote Originally Posted by duey View Post
    I'm all over it Duey, thanks! It's coarse threads on GSX-R600K6, GSX-R600K7, GSX-R750K6, GSX-R750K7 in case anybody wanted to know.
    I have been running the woodcraft set-up for a while now on my SV. No troubles with the non-existant return spring and the pressure sensitive brake light switch works perfectly.
    Super Duper DankDirtyBird's Avatar
    Re: Woodcraft rearset installation
    Question about this. When wiring up the pressure switch, why the hell did they put a plug on one end and just give you little metal connectors for the other part? Am I missing something?
    You Sir know nothing of true greatness. I of course refer to ones ability to steal, drink and generally do nothing, and carry it off with style
    Just connect the wires however you can, whether youve got to cut a set of connectors off one side or the other.
    Derry NH
    Way to dig up an old thread...
    Anyway, that's because the pressure switches are universal, and all bikes have different plugs, so they just don't bother putting a plug on cause it likely wouldn't plug in anyway.
    who knows
    Quote Originally Posted by DankDirtyBird View Post
    Quote Originally Posted by Eric Baker View Post
    i just cut the connectors off the one i got from woodcraft and soldered the stock connector on and bing bang boom. plug and play and works like a charm.
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    Cut...put included connectors and connect.....oh and use heat shrink to cover it up
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    "Plymouth's Fastest" BrianC's Avatar
    Sep 2010
    Plymouth, MA
    http://www.nestreetriders.com/forum/...-rearsets.html
    Not sure if this helps but it is what I did w/my r6. My rear brake light functions perfect and I didn't buy the pressure banjo.
    LRRS am #121
    Funny thing about that Eric, I searched on NESR and didn't find what I needed. Hit up Google with the same search, and this was the second organic search result.
    Strange enough, the pressure switch from woodcraft comes with a plastic connector plug already attached. It looks like it should hook into my RC Car battery. I guess i'll just hack up the stock switch and take the plug off that bad boy.
  1. Woodcraft rearset Brake light switch 08 GSXR1000
    By Drewgrace in forum Bike Maintenance
    Last Post: 05-05-14, 11:58 AM
  2. Woodcraft rearset questions
    By stanga5o in forum General Bike Related
    Last Post: 09-29-13, 08:49 PM
  3. Woodcraft Rearset GXSR1000 2008
    Last Post: 03-13-13, 01:26 PM
  4. Replies: 7
    Last Post: 06-21-11, 11:29 AM
  5. FEELER: Woodcraft rearset
    By sdog30 in forum For Sale
    Last Post: 03-10-10, 11:15 AM
