Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 112
Foot Placement.....Help
  1. #76
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Foot Placement.....Help
    Pigman... Not to pick but in your Avatar you could loosen up in the arms a bit too.
  2. #77
    No...I need the help
    Yea, I tried to be more in the tuck and loose last time out...I appreciate the help and would love to get a few laps on Video and get some feed back.See where I can improve..I will post the last track day pic as soon as I get it. I really want to Learn more so any advice is Greatly appreciated...
    shawn
    Quote Originally Posted by Ken C View Post
    Someone out there must have a good action photo showing this??
    OHHHH fiiiine... HIGH RES!!!
    www.cheapbastidracing.com/media/feet.JPG
    ... this actually shows my foot fully tucked against the frame, not on the end of the footpeg... which is where I usually end up while on the SV with its more up & back rearsets.
    You can also see I usually end up more on my toes than the ball of my foot.
  4. #79
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    shawn
    We usually do a body position seminar between the two days during the two day TTD events. If we haven't done it recently it's because it wasn't apparent that there was much demand for it.
    As far as learning goes, keep an ear out for an off-season seminar or two. There will be one on traction management and perhaps I will add a body position seminar to the schedule.
    outside foot, ball. I can't reach far enough to put my arch down.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    I posted a pic on PAGE 1 showing what Denno ended up yapping about pretty clearly I thought. In case it wasn't clear enough.
    Red = peg
    Green = sole
    Blue = toe slider
    Boston --> San Diego
  7. #82
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Pete our FEET look identical.
  8. #83
    Nov 2007
    I think I am in a similar boat since I have a short inseam, I know you do as well.
    Chris: You look like you are too much on your toes.
    You mean on the outside foot? Are you sure? Those two pictures I posted were Denno on my bike, and Me riding his bike...?
    Zip-Tie Alley Racing
    LRRS/CCS #103
  9. #84
    I've got hairy hobbit feet.
  10. #85
    Sep 2001
    Western MA
    Here are a couple of photos showing where the footpeg end contacts my sole and my outside foot placement.
    Yea, I saw BrendanP's and it was the same witch brought this Q up. I was told to be slightly behind the Balls of your feet..Clearly you are a bit past..and out.
    Oct 2007
    Peabody Assachusetts
    I'll post up a pic of my sole tonight...
    and it is which, not witch... you got Halloween on your brain?
  13. #88
    Quote Originally Posted by brendanp View Post
    No, I am Illiterate and can't spell for chit…..what you didn’t read my post....
    Oct 2007
    Actually, he looks scared shit. I would be too! It was raining that day!
  15. #90
    LRRS Rider #256 QuarterGig's Avatar
    Gorham Maine
    GAH why coulden't we have this thread mid season when i could work on this stuff. This is fantastic information.. Thanks guys.
    Seth
    LRRS/CCS NV #256
    2007 Ducati S2R1000 Street
    2000 Triumph TT600 Track For Sale
    1984 Honda Magna needing reassembly.
    1974 Honda CB 750 needs wiring
    1974 Honda CB 350 needs engine work
  16. #91
    Old and Slow Sheppo's Avatar
    Westford, Ma
    what's interesting to me ( a noob ) is, with both feel you don't cover the shift lever or the brake. My assumption is you would move your foot to use either?
    I am learning a lot this is great.
    Posted by Jane in BoxChat
  17. #92
    Lifer Pittenger5's Avatar
    Austin
    These things have brakes you can work with your feet?
    Apparently Im still just off to what all the fast guys do, I dunno if its a good thing or not, but I just dont have the ground clearance to keep my feet that far on the end of the peg.
    Pete you ever have that problem on your EX?
    Zip Tie Alley #505
  18. #93
    Tucson, AZ
    What I do is move my foot long enough to shift (I never touch the rear brake, either on the track or really on the street, save for emergency stops) and then move it back to the ball of my feet. We're mostly discussing foot placement in corners, so shifting and/or braking will (hopefully) not be necessary.
    Original
  19. #94
    Westford, Ma
    Quote Originally Posted by jnm988 View Post
    I understand this is cornering and the lack of back brake usage, just making a note. I am sure the foot doesn't shift from one place to the other for straight vs corners.
    This is teaching and old dog ( or doug ) new tricks
  20. #95
    Austin
    Your foot moves simply because body position dictates. On the straight all the weights (theoretically) on your ass and at least evenly divided between both feet. The second you hit a corner EVERYTHING in that equation changes, most if not all your weight goes to a foot, with the weight balance thrown off, so you need to change position a bit if for nothing else than your body is now in a different postion and the mechanics of your body changes.
    Zip Tie Alley #505
  21. #96
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    its pretty self explanatory...doesn't require much thinking on how its done. Just need to ride on the balls of your feet, to get your knee out your foot needs to rotate a bit, thus moving it out on the peg to give it room to do so is necessary.
    keep in mind that over thinking minor things eats up a lot of your $10 worth of attention that could be spent on more important things
    Westford, Ma
    Exactly. I understand that!
  23. #98
    Tucson, AZ
    Well... for myself... I found that I made the most progress when I slowed down and worked on one thing until it was second nature. I know foot placement makes sense to you because you've done it for so long, but it baffles me. Probably because I have huge feet.
    Original
  24. #99
    Austin
    So what advantage does putting your foot at the end of the peg offer? Like I said I tend to have my foot essentially on the frame, do you get more leverage or anything with it out, or is it more personal preference.
    Zip Tie Alley #505
  25. #100
    Sep 2001
    Western MA
    It provides very firm contact and is at a point in the foot where feel is quite sensitive.
    I've positioned my feet in several different ways depending on the bike I'm on and the amount of ground clearance i have. There is really no right or wrong way. The point is to keep your foot out of harm's way and to allow firm contact for easy movement and for weighting the pegs as necessary.
  1. lulz... nice wheel weight placement...
    Last Post: 11-24-13, 08:46 PM
  2. 6-7 foot by 10-12 foot enclosed trailer
    By OreoGaborio in forum Wanted
    Last Post: 08-31-12, 07:35 AM
  3. Need some advice on bike placement on a trailer
    By Evadd in forum General Bike Related
    Last Post: 05-20-12, 09:22 PM
  4. Tag Placement Rules In Massachusetts
    By Eddie in forum General Bike Related
    Last Post: 08-12-09, 05:23 PM
  5. Track day group placement???
    By nilez in forum General Track Day Talk
    Last Post: 04-11-08, 12:09 PM
