Page 16 of 24 FirstFirst ... 6789101112131415161718192021222324 LastLast
Results 376 to 400 of 590
100 DAYS UNTILL 2014 RACE SEASON
  1. #376
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Re: 100 DAYS UNTILL 2014 RACE SEASON
    24 Days
    Posting Freak Gecko's Avatar
    Jul 2008
    Other than wire brushing and a dab of motor oil, what else do you guys do for rust on cylinder head exhaust studs & nuts? They came off easy enough, but would like to prevent any future trouble. TIA.
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
  3. #378
    Lifer union's Avatar
    Blackstone, MA
    You can try some never seize but they are exposed to everything so its tough.
    Or you could try something like this http://www.mcmaster.com/#rubber-end-caps/=rbz3ze
    James
  4. #379
    If you're talking about your header bolts, I use never seize every time they go back in.
    Same for caliper and brake pad bolts.
  5. #380
    Jul 2008
    First time I've ever encountered rust like this on a bike. On the R6, they're studs that stick out from the cylinder head on which nuts screw onto. Not looking to re-do the studs now, maybe on a rebuild. Did some searching prior to posting and consensus seems to be to skip the anti-seize ... not sure why, maybe the high temp does something funky to that stuff? Just looking to arrest the rust for future easy on/off of the nuts.
    John
    CCS/LRRS Expert #69
  6. #381
    first time i've ever heard to not anti-seize the header bolts.
    curious to the reasoning behind it
  7. #382
    The only reason I can think of is you're putting a tacky coating on the bolt, it's in an area where it's going to collect crud. That combined with heat means you'll have a baked on mess to try and ram the nut over when you'll go to remove it down the line?
    Durham
    Electrical is pretty much all back in except for a couple plugs that go to parts I haven't put back on yet. Subframe is on, rear suspension needs to be torqued down but is in place. Rear wheel and head bearings replaced. Progress continues to be slow but it's moving along. Hitting a wall with the front wheel bearings though. No matter what I try I can't get the damn things out.
    For those not on Facebook, here's a sneak peak:
    I got a lot done over the weekend. I mounted the plastics. It looks wicked! Thanks to Lee at Skid Mark Racing/Motorsports.
    I switched tanks, which is SO much more of a PITA than on the SV, since the RSV's tank has the fuel pump inside of it. Thanks to Annalisa for giving me a hand and being patient with me.
    I also swapped the stock clip-ons for a set of Woodcraft. I also did most of the stickers and replaced/installed heat shielding on both SV and RSV belly pans.
    Not much left, except the chain & sprockets, replacing antifreeze with water/wetter, and an oil/filter change.
    I can't wait until 5/12 to get this out on the track.
  10. #385
    Apr 2011
    NH
    thanks, now I'm not worried about tech at all.
    Tim
    LRRS #44
    Superbike Services 44
  11. #386
    Quote Originally Posted by timmyho414 View Post
    Is that because of my numbers? I also have them on the other side of the intake.
  12. #387
    5/12?
    yes, that way he can hear about my 4th race weekend, before he even does 1 lap
  14. #389
    5/12?
    Not doing round #1 or the first set of TTD. Other commitments. So, I'll be starting round 2 from the back row.
    And the RSV probably won't be raced until at least the Classic. I need to get used to it.
    As for 5/12, that's the 2nd TTD at NHMS.
  15. #390
    Apr 2011
    NH
    yea the number, were not suppose to be fancy. I got a couple sets of plan black with an outline and have been wondering what they'll say.
    yours looks good by the way.
    100 DAYS UNTILL 2014 RACE SEASON-0308140734-jpg
    Tim
    LRRS #44
  16. #391
    I ran the "chilled" font last year and they didn't say anything. As long as the scorer can read the numbers clearly.
  17. #392
    Oct 2007
    Littleton NH
    23 days
    if you have a 2 digit number, it doesnt matter. the lower the number, the better.
    i remember when a garagemate walked into tech with no helmet, flat rear tire, and nothing wired....passed tech.
    yet the yellow plate bikes failed tech because our front numbers were 5.5" and not 6". or the "1" had the little tail up top and didnt look like "l"
  19. #394
    Jan 2012
    Lowell
    100 DAYS UNTILL 2014 RACE SEASON-img_3199-jpg
    This passes
    not according to the rule book though.
    if they wanted to, they can fail that
  21. #396
    Jan 2012
    Lowell
    When you're as sexy as me you can get away with anything... you wouldn't know Jim.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    if there's a half inch of white between the outline and number then its actually perfect in the wording of the rulebook.
    Quote Originally Posted by shortbus View Post
    This passes
    I would have failed that
    Apr 2011
    NH
    ^^^^^ that looks like a kid drew it with a crayon.
    and there isn't.
    Tim
    LRRS #44
  24. #399
    Meriden, Ct
    Maybe they break your balls because they can't believe how you could still be an AM with as much racing as you've done. :huh:
    This passes
    Bravo my friend... Take a bow. That's fucking awesome.
    Oct 2007
    Littleton NH
    22 Days
    and no not the lower the number the better anymore..... it used to be like that. past champions were allowed double digits and now anyone can get one
  1. 49 days till race season starts
    By Jim in forum Pit Area
    Last Post: 03-11-16, 12:31 PM
  2. 94 DAYS UNTILL 2015 LRRS RACE SEASON!!!!!
    By lrrs428 in forum Pit Area
    Last Post: 05-14-15, 05:10 AM
  3. 2014 race season...
    By DZircher in forum Pit Area
    Last Post: 09-28-13, 12:42 AM
  4. Count Down Untill 2013 Season Kicks Off!
    By lrrs428 in forum General Bike Related
    Last Post: 04-29-13, 12:49 PM
  5. Count Down Untill 2012 Season!
    Last Post: 04-28-12, 07:19 AM
