Either way Id rather try and mount them up first. This way you can fix anything you need to from mounting and drilling before you paint. I have yet to find a set of bodywork that just fit right up without some sort of modification. At least tell me you didnt just go and drill holes where they suggested.
It had already some holes. I bought them from Gino.
I will need to make some modifications for sure for the frame sliders to come through and something to hold the lower fairing more secure. Wanna help??? :-)
Haha Worcester MA around 3-4pm to start? Or maybe even later..
I was thinking Saturday?
I could be over there saturday evening Sav. Is your bike drilled for wire yet?
The things I KNOW have to be drilled yes they are. The bike has been raced previously (I think) so it should be. However surprised might occurre but we will have a full automotive garage available to us with plenty of tools to do whatever we have to do :-)
Oh and you bringing the wire for me right? Haha. And maybe your plyers? Unless my $6 hf ones will do it?
R.I.P. - Reed - 3-23-2008
I actually won't be in Westfield Saturday because I am teaching a MSF class. I am only going to be able to make it on Sunday. But you can come hang out at Sav's.
And Sav your pliers will be fine. I have basically the same ones but I bought them from PU. I will order the wire tomorrow. Should have it in sometime this week.
I drained the tank of water, it holds pressure, air that comes out of the bladder is dry with no odor. I've got a professional plumber coming Tuesday to help diag. What I can see at the moment is once the pump shuts off, the water level is dropping in the supply line, drawing a vacuum. When the pump comes on, there is a good 4 to 5 second delay before the water reaches the in house check valve. If the pressure tank has water in it (system is at cut-in pressure, 38psi or so) when it hits I get a single hammer at the 'T'. Then it fills as normal till hitting the cutout at around 58psi. I'm thinking it's gotta either be the check valve in the pump or I've got a leak in the pipe between the pump and the house.
25 Days
Payment is you are buying then Sav
PS...just ordered your safety wire this morning bud.
ok so $20 for drinks for you and $350 for me
Why do you have spare check valves kicking around?I actually put a new one in this weekend, no change in behavior. That's when I decided it was time to have a pro come and check my work 'cause from here if I did everything right it gets expensive. I'm kinda hoping he finds a mistake on my part.
24 Days fuuuuuuuuuuuuuuuuuucccccccccccccccccccckkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkk
Holy shit this is happening
