Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 101
Where do you shift?
  1. #76
    Re: Where do you shift?
    Well, since I finally got up to Loudon, here's where I was really comfortable:
    CBR900RR 16/43 (stock gearing):
  2. #77
    Lifer eboos's Avatar
    evil weasel saved me from having to post a map. My shift points are exactly the same.
    Edit: I stay in 3rd through the exit of turn 2 and up shift into 4th before down shifting into 2nd for turn 3.
  3. #78
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Updated for current racebike: 2005 RMZ450
    This will most likely change a bit more early next season, but for now...
    Boston --> San Diego
  4. #79
    Lifer Pittenger5's Avatar
    Austin
    MUAHAHAHA. Less work for DB
    Zip Tie Alley #505
  5. #80
    Jun 2005
    six speed motard:
    1000CC GSX-R:
  6. #81
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    ha ha @ GSXR map!
  7. #82
    Austin
    But wheres the wheelies?
    Zip Tie Alley #505
  8. #83
    ha ha @ GSXR map!
    +1
  9. #84
    six speed motard:
    1000CC GSX-R:
    i shoulda taken your motard if i knew it was a 6 spd
  10. #85
    Jun 2005
    I think my KTM was the only bike you didn't ride... oddly, I think you're the only one who didn't ride my KTM.
    All you gots to do is ask, bro
    didnt even think of it. not to mention you spent a lot of time on it since you were scared of the 1K
  12. #87
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    6-speed on a motard is actually overkill. It's way too much shifting. The 5-speed tranny is the hotspot for motaaaards.
  13. #88
    Jun 2005
    Why I oughtta!!!!
    I agree. The katoom was a 4spd in stock trim... all I did was add 5 and 6. 1-4 kept the stock gears. If I did it again I'd see what was available to change 1-4 as well. The bike pretty much requires short-shifting. It does tend to get in the way... It's ready to upshift when leaned over way too much (2, 7, 10/11, etc)
    i guess it depends on how its geared. Joels Husky was a 6spd and was perfect. i was grabbing 6th over the hill and it had plenty for the front straight.
  15. #90
    Jun 2005
    And in my case how it's ridden. I could (should) be carrying more speed and come in a gear higher in the spots where it's been problematic. I messed with it a little on Tuesday but am not quite there yet.
    is that why i lapped you twice on Zacks motard? j/k
  17. #92
    Jun 2005
    you did no such thing!
    um, did you?
    you probably pitted in. then went back out just in time for me to pass you
    OK im done bustin your balls.........i think
  19. #94
    Jun 2005
    yeah yeah... pitted in cuz you were holding me up, man.
    KB KB's Avatar
    Manchester NH
    Tricky you can do more shifts at once if you rev that mo-tahd out. Let it sing...................it's a dirtbike. Grab gears, let it hummmmmmmmm.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  21. #96
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    this is exactly how I shift.... I should short-shift 5th at the end of the straight, and short-shift 4th at the end of the back straight though...I do sometimes but I don't normally. I also hit the rev limiter coming through T7-T8 sometimes. Thats with 15/49 gearing.
    Posting Freak Gecko's Avatar
    Jul 2008
    I wanted to follow up with you on your earlier post in this thread, but I could not remember what sprocket I have on my R6 to make any discussion worthwhile. I *think* I'm running a 48 (I'm going to check this evening). What tires are you running?
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
  23. #98
    Canterbury, NH
    Quote Originally Posted by Gecko View Post
    I'm running Dunlop 211 Ntechs.
    But yea, going to the right sprocket definitely cleaned up my shifting....so much easier now.
    Member garath's Avatar
    Wallingford, CT
    That's exactly what I ended up doing by the end of my first (and only) day up there on my ZX-9R with stock gearing.
    Jul 2008
    Dunlop slicks here. Same size.
    Originally, I *think* I had the 49 on the bike (need to check my notes). With the suspension unsorted, it felt like I was shifting everywhere with the 49. So I put the 48 on and my shift patterns matched my '03 R6. Though the '06 would bog sometimes, at least the shifting was in a comfort zone for me to focus on the suspension. After I got the suspension sorted out towards the end of the season, the 48 felt good as long as wasn't following anybody (low to mid 16's with open track). The minute I got stuck behind somebody, however, I was stuck and couldn't get a decent drive out of any corner to keep up to try and make a pass on a slower rider going into the next corner. I wanted to try the 49 (again) but I had left it home in the parts box.
    John
    CCS/LRRS Expert #69
  1. Broken Shift rod
    By ducatirdr in forum Pit Area
    Last Post: 04-17-17, 01:33 PM
  2. GP Shift
    By Petorius in forum Pit Area
    Last Post: 09-18-15, 11:17 PM
  3. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  4. GP shift?
    By Awesome in forum Pit Area
    Last Post: 05-05-05, 05:07 PM
  5. GP Shift
    By snaggle in forum Bike Maintenance
    Last Post: 07-18-04, 12:30 AM
