Page 1 of 7 1234567 LastLast
Results 1 to 25 of 159
The (not so) Great Gixxer Rebuild
    * please keep this thread on topic *
    Work has been done in Degsy's garage this week to get my bike ready for PCIII tuning At RJ's Motorcycles on Saturday & for my long ass bike ride coming up in 2 weeks.
    Day 1:
    Started by taking off the tank mounted HyperPro damper, and lifting the tank.
    Took out the air box and cleaned the K&N air filter
    The (not so) Great Gixxer Rebuild-2008-08-13-clean-filter
    The motor didnt look at shiny as the chrome on the bike, but it's expected on a 6 year old bike with 20k+ miles
    The (not so) Great Gixxer Rebuild-2008-08-13-engine-jpg
    Next was new plugs. Took out the NGK 9E plugs and replaced them with NGK Iridium IX plugs. Below you can see how badly I needed this done.
    The (not so) Great Gixxer Rebuild-2008-08-13-plugs-jpg
    Next was the new Gafler stainless brake lines and new DOT4 brake fluid (thanks GixerJockey).
    The (not so) Great Gixxer Rebuild-2008-08-13-brake-linesThe (not so) Great Gixxer Rebuild-2008-08-13-jpg
    now it's 1:30am and it's time to call it a day.
    Re: The (not so) Great Gixxer Rebuild
    looking good let me know how the SS lines feel. with the map done i might ride behind you for once.
    All strippers SHOULD have fake tits!
    Day 2:
    took this opportunity with the front end off to remove that pesky stock damper that everyone gives me crap about. It wasn't easy as Derek and Nate were there to give a hand & can tell you how frustrated I got getting this thing off.
    Tried to heat the bolt to use a striped bolt socket...FAIL
    The (not so) Great Gixxer Rebuild-2008-08-14-003-jpg
    So we went to option B
    [youtube]http://www.youtube.com/watch?v=ty6Gx11j4qo[/youtube]
    The (not so) Great Gixxer Rebuild-2008-08-14-007-jpg
    Used a drummel to shave off the allen hex nut for the other bolt. then the drummel wheel was toast and couldnt find any new ones. Ended up resorting to a hammer and smashing the fugger off. damper is FINALLY off!!!
    The (not so) Great Gixxer Rebuild-2008-08-14-011-jpg The (not so) Great Gixxer Rebuild-2008-08-14-010-jpg The (not so) Great Gixxer Rebuild-2008-08-14-013-jpg
    Time to tear down the entire front end to replace those steering head bearings. This part may help some if you, since there has been interest lately on the boards on how to replace these. R1slowflyer, this is for you
    Removed the front end including the lower triple and forks.
    The (not so) Great Gixxer Rebuild-2008-08-14-014-jpg
    now the upper triple, and jack the bike up by the headers
    The (not so) Great Gixxer Rebuild-2008-08-14-015-jpg
    here's where all the bearings go. once the old racers go out, make sure to give it a good cleaning.
    The (not so) Great Gixxer Rebuild-2008-08-14-016-jpg
    new bearing kit
    The (not so) Great Gixxer Rebuild-2008-08-14-019-jpg
    comparing the old vs the new
    The (not so) Great Gixxer Rebuild-2008-08-14-031-jpg
    Derek's trick on installing these: put the new bearings int he freezer overnight. Heat up the old bearings for easier removal using a flat head screw driver and a hammer. NOTE: do not hammer your thumb multiple times. It hurts. *cough* Derek *cough*
    The (not so) Great Gixxer Rebuild-2008-08-14-020-jpg The (not so) Great Gixxer Rebuild-2008-08-14-022-jpg
    take the new frozen bearings and they should drop right in the frame now that the heat expanded it. You will need to 'persuade' the new ones in to make it fit all the way in. We used a socket over the bearings and hammered them in.
    The (not so) Great Gixxer Rebuild-2008-08-14-029-jpg
    top's done
    The (not so) Great Gixxer Rebuild-2008-08-14-026-jpg
    repeat the same steps for the bottom part of the bearings.
    take the bearings off the lower triple and replace them. This step we couldnt finish, since the bearing was on there so tight. We used heat and couldnt budge it. This part is getting brought to a place today for removal of the old and install the new bearings.
    The (not so) Great Gixxer Rebuild-2008-08-14-030-jpg The (not so) Great Gixxer Rebuild-2008-08-14-032-jpg
    how the bike currently looks
    The (not so) Great Gixxer Rebuild-2008-08-14-033-jpg
    plastics off to the side
    The (not so) Great Gixxer Rebuild-2008-08-14-035-jpg
    front (chrome) wheel, fender, and fairing stay
    The (not so) Great Gixxer Rebuild-2008-08-14-035-jpg The (not so) Great Gixxer Rebuild-2008-08-14-036-jpg
    now it's 1:00am and time to go home. Day 3 pictures tomorrow
    Quote Originally Posted by 1/2pint View Post
    the lines are unbelievable when squeezing the level in comparison to the other gixxer's in his garage with stock lines. I have new front pads on the way that I ordered yesterday.
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    i couldn't get the race off the stem either when I replaced my head bearings ... such a PITA
    Quote Originally Posted by s a x m a n View Post
    i guess it's a lot easier on CBR's, but GSXR's are a pain. how did you get end up getting yours off?
    Oct 2007
    Peabody Assachusetts
    Jim, I am very impressed with you. And I thought the most you were capable of doing was putting air in the tires!
    Just dont let Denno put the rear wheel on!! hehehe
    Quote Originally Posted by brendanp View Post
    or frame sliders. honestly who cuts the plastics, misses the spot. cuts another hole in the plastics on the same side. THEN realizes they're no-cut frame sliders
    but ya, this bike should be all back together tonight, so i can tow it to NH tomorrow for my custom map
    Everybody to the limit!
    Winchester, MA
    Fascinating pictorial. Ooh, an air filter. Ooh, spark plugs. Old AND new spark plugs. It doesn't get any better than this. But wait! Stainless lines in the packaging! Excitement!
    Foxboro, MA
    Jim,
    Degsy is doing everything and you're taking pics. Dont pawn it off as you know what the hell you're doing you waste of space. Eat my asshole Jim, eat my asshole.
    When I need my chain or taint cleaned I'll give you a call
    Best,
    Denno
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Denno, let's hear about your wonderful rear tire job recently. by the way nice avatar
    Meriden, Ct
    Any comments about crashing ON THE RACETRACK are off limits to you until you pull the string on your manpon and do a trackday! :
    Noel, have you ever replaced steering bearings on any of your gixxers? did you run into the same problems on the triple stem as saxman and I had?
    Foxboro, MA
    you're a bozo jim
    2006 Yamaha R6
    Denno i'll be there again tonight if you want to stop by. If you do, make sure you show up after all the work is done and offer help....just like when the garage was cleaned out for the new floor.
    Meriden, Ct
    Yes... and, no...
    Yes, I have changed my fair share of steering head bearings. Yes, they're always in there "tighter than a nine year old boy, fresh out of the orphanage".
    No... I havn't had a really hard time. I have a 15 ton bearing press in the shop. It makes quick work out of bearing removal and installation.
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    Yes... and, no..
    Noel, where's this orphanage you talk about?
    Q
    Meriden, Ct
    Quote Originally Posted by Qfactor View Post
    Q
    That question disturbs even me... And I posted it.
    I'm honestly starting to reconsider my accomodations down at VIR...
    Foxboro, MA
    BUY OUT!
    2006 Yamaha R6
    Homeless, MA
    you'll bring more young boys or less young girls with you?
    hahaha
    Q
    Meriden, Ct
    Quote Originally Posted by Crash Dummy Denno View Post
    BUY OUT!
    buy out what???
    Nov 2007
    Jim this is fucking terrible. Have I taught you nothing?
    1. This is not a rebuild. This thread should be titled 'maintenance'.
    2. Derek did all the work for you. He should be charging your ass labor fees.
    3. Your pictures are poorly taken and NOWHERE near high enough resolution.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Meriden, Ct
    Quote Originally Posted by ceo012384 View Post
    Nov 2007
    This is not a joking matter, Noel
    Jim, please refer to my garage and bike build threads for proper technique on:
    • Creating long build threads
    • Multi-quoting like a champion
    • Building low-ceiling garages
    • Taking and posting high-resolution pictures
    • Owning and maintaining a bike that isn't a chromed-out garage queen piece of junk
    Have a nice day and fuck you very much.
    LRRS/CCS #103
    Foxboro, MA
    POW!
    2006 Yamaha R6
  1. first 2 stroke rebuild
    By black in forum Dirty Bastards
    Last Post: 01-25-17, 05:24 PM
  2. R6 caliper rebuild
    By Dip Dungles in forum Bike Maintenance
    Last Post: 02-19-13, 07:14 PM
  3. Great Ride Sat with great friends
    By GingahNinjah in forum General Bike Related
    Last Post: 05-21-12, 06:26 PM
