Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 151 to 175 of 381
Bad decisions were made today..
  1. #151
    High maintenance priss
    Central MA
    Re: Bad decisions were made today..
    @R7 - is this what the nut is supposed to be or does it have a hex head like in your post?
    Bad decisions were made today..-r7axlenut-png
    Either way: if you know the specs, I would be honored to make a part for a such a beautiful bike if it comes to that.
    TWINS! xrocket21's Avatar
    Central Maine
    Love this community!!!!!!!!!!
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Yea, this thread is awesome. I had no idea how cool these bikes are. Just assumed they were a typical "race replica" .
    That’s a great offer and I really appreciate it. I may take you up on that.
    I have the piece in your picture, which is the original R7 part. The difference on my bike, is the fork bottoms are different. The fork bottoms on the bike, don’t have the holes drilled or tapped for the 2 smaller locking nuts. The sleeve portion OD of the original axle nut is also smaller than the ID of the fork bottom.
    I think it’ll be cleaner to have the hex head rather than drill and tap the fork bottoms for the two locking bolts
    Central MA
    Gotcha. Agreed on not tapping the lowers you have. Seems pretty straight-forward. The right-hand side use a spacer or is it machined into the axle itself?
    Lifer union's Avatar
    Blackstone, MA
    You can try an ohlins dealer for that part. The forks are pretty standard from them and the insert are what are specific.
    James
  7. #157
    The right side also has a spacer. I have 1 correct spacer, that will work on both sides. In theory, I could buy, or have a copy made of the one spacer I have, and make it work. It would not solve the nut side being locking I added a couple pictures of the sleeve spacer that came with the bike
    I’ve tried reaching out to Ohlins, and even searching their site for parts. Any similar part gets redirected to the Japanese site where the parts listed, are bike specific. If dimensions of actual parts were listed, I think I can figure out the correct part to buy.
    By the way, thank you again for the brake calipers. I’m waiting on the bolts and spacers to mount them.
    Bad decisions were made today..-img_6727-jpg
    Bad decisions were made today..-img_6726-jpg
    This is some weird axle voodoo here. What in the world is the point of this hardware?
    Blackstone, MA
    Looks like Ohlins R&T forks. I'm pretty sure all the bottoms are the same. So you get whatever hardware from them to adapt to your bike. This bike also has aftermarket wheels on it.Could have been wheels meant for a different axle and knowing what this bike is a custom made piece isn't out of the question. Of course without seeing whats going on first hand I am completely taking a guess.
    James
  10. #160
    I think the axle parts are a mix of original R7 parts, and some aftermarket/Ohlins parts. In an ideal situation, I’d like to find all the original R7 parts… tho that is the most unlikely scenario.
    I have the OE wheels that came with the bike, they are the same axle size, same spacing, same brake rotor mounting as the aftermarket carbon wheels. I’ve tried them both on the bike, I have the same issues with both sets of wheels.
    I’ve reached out to Ohlins USA, the guy wasn’t much help. His focus was on 30 year old parts not being made anymore, even tho I gave him the dates the prior owner was doing this conversion, which was 17-18 years ago. The part I found from WeBike in Japan, looks like what I need, I may just order it to see.
    I’m dropping the bike off this afternoon at a shop to get the coolant pipe made. Once I get it back, the focus is on the airbox.
    The front brakes should be sorted as well, I have the new TI mounting bolts, just waiting on the correct TI 10mm caliper spacers to show up.
    What’s the preferred stainless brake line brand being used? And originally the R7 had 2 lines coming from the master, one line to each caliper. My Tuono has the same brake calipers I’m using on the R7, with one line from the master, and a line connecting one caliper to the other. Is there a preferred method?
    I've got some Galfer Superbike lines that are pretty sexy. Two full length lines from MC to each caliper...
    But IMO, any of the typical routing methods is fine. I haven't really heard many solid arguments for or against any of them in particular. Whichever set-up you like best based on personal taste.
    https://www.galferusa.com/technical/...dentification/
  13. #163
    Oct 2008
    NW CT
    Only thing I can think of is the loop from caliper to caliper could hold an air bubble.
    so i chased a brake issue for a season and ended up being worn bleeders. did all the obvious things like rebuilt calipers with fresh seals and pistons (two sets), new fluid, swapped masters....still sucked. i zip tied my lever over night and found fluid seeping out of both bleeders on both sets of calipers. $5 from the dealer and i was good to go. dont waste your money with speed bleeders or anything aftermarket.
    another trick i've seen is TSE will take a complete brake set and hang them upside down to let air pockets move for easier bleeding.
    one trick i've personally encountered, which i dont recommend is crashing. bike took a hard hit to the ground, bled the calipers and it magically shook out all air pockets after. brakes were amazing after. again, dont recommend this method unless you're on an SV, EX250, or something that will gain value from it having some pavement marks.
  15. #165
    Blackstone, MA
    I'm running Spiegler lines on the hog. I went their type 950 route. 1 Line from the master to a T that puts 1 line to each caliper. They made the lines to my spec lengths. Worked out great. I would do that again if I needed to. They can be customized many ways. I've also used goodridge lines in the past with good results and galfer lines.
    James
  16. #166
    Lifer LuvDog's Avatar
    Ashland, MA
    I've run mostly Spiegler lines. And I always preferred separate lines from the MC.
    2003 ZX7R
    1995 916
  17. #167
    Tomorrow I pick the bike up from the fabrication shop that I had the coolant pipe made at. We had decided on making it two piece and connecting it with rubber hose. It was difficult to make as one piece and stay straight once welding it together. These are the pictures he sent me.
    Bad decisions were made today..-img_5932-jpg
    Bad decisions were made today..-img_5934-jpg
    Bad decisions were made today..-img_5929-jpg
    9 Not allowed! Not allowed!
    Central Maine
    Love good fab work. Very nice.
    Freshhhhhhh
  20. #170
    Lifer Gixxer's Avatar
    I realize this R7 is a limited icon, and the new R7 is a completely different bike… but the new R7 is listed as an inline 2 cylinder…. Is that different from a parallel twin?
    Your park avenue leads to..
  21. #171
    Inline 2 cylinder and parallel twin are the same engine configurations.
    And this R7 is clearly an in-line four cylinder with a traditional screamer crank (unlike current R1 with a crossplane)
    CCS/LRRS #83
  23. #173
    I had a crossplane R1, sounded great. Kinda digging the new MT-10 with the teal wheels, hoping it’s the crossplane engine in it..
  24. #174
    I can't remember if I posted this somewhere else on the board. But I had a very interesting discussion with a very cocky salesgoon at Mom's Manchester a while back...
    I was giving a new R7 a look-over and an extremely cocky salesgoon came over to give me the spiel. I commented how far it had wondered from the '99 R7 I was somewhat familiar with. That condescending prick treated me like a school girl, speaking just loud enough to make sure anyone within earshot could hear him, basically telling me what an idiot I am. Gave me the whole, "I've been involved with motorcycling my whole life" bit. All the while I was calling it up on my phone. Dipshit grabs my phone, canters over to his computer and taps away. I could tell by the following 30-45 seconds of silence that he was crafting his mud-in-the-face reply. It was fuckin' hilarious waiting for it. He made some back-handed comment about that one being back in '99, blah-blah-blah.
    Now we had a couple customers that were kinda following along from a distance. Just loud enough for those who were listening to hear, I basically told him that someone with his motorcycle knowledge should really know the product he's selling and maybe the brief history. I got a chuckle, he just sat at the desk looking dumfounded. Being the narcissistic prick he was, he of course had to get the last word once again mentioning that it WAS back in '99, and it had nothing to do with the current model. My reply before trotting out was, "yeah, except the R7 moniker, huh?" I got a couple more chuckles after that...
    5 Not allowed! Not allowed!
  25. #175
    "...THANK YOU FOR MAKING MY POINT! I'M GLAD TO HEAR YOU NOW AGREE WITH ME AFTER TAKING A MOMENT TO EDUCATE YOURSELF!"
