Page 13 of 16 FirstFirst ... 345678910111213141516 LastLast
Results 301 to 325 of 381
Bad decisions were made today..
  1. #301
    Re: Bad decisions were made today..
    The guides are unavailable. The one guy in the UK most likely to have parts for this bike, doesn’t have any guides.
    are the guides machinable ?
  2. #302
    I’m sure they are machinable, will it be cost effective? Unlikely.
    I can get a new old stock head with guides (no valves, springs, cams, etc). for $3,500 plus shipping. I don’t think these guides can be copied and made for that kinda money.
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Kinda surprising that guides aren't available but a NOS head is??
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
  4. #304
    Quote Originally Posted by joeswamp View Post
    You can make more power with the head made for NOS tho.
    Nothing is available through Yamaha, these parts are all owned by a private party.
    If it does come down to guides, let me know, my expectation is guides could be sourced and installed for much less than $3500, they're fortunately not overly complicated parts.
    Lifer obsolete's Avatar
    Norf Sho
    Guides are essentially just a bronze sleeve, no? I'd think that'd be much cheaper than 3500 to have machined. But Im also talking out my ass.
    -Alex
  8. #308
    Seven of the eight exhaust valves are stuck in the head, and made contact with the pistons. Head is getting disassembled now and I’ll be getting the parts list later today. The search will be on after that.
    Bad decisions were made today..-img_9268-jpg
    Bad decisions were made today..-img_9267-jpg
    Lifer LuvDog's Avatar
    Ashland, MA
    Ouch
    2003 ZX7R
    1995 916
  10. #310
    Walpole
    Well that sucks! But now that the motor is out you can have it all cleaned up to your standards.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
  11. #311
    is there anything that could have been done prior to trying to start it, to prevent damage?
  12. #312
    Lifer union's Avatar
    Blackstone, MA
    That really sucks! Good luck finding what you need.
    James
  13. #313
    Norf Sho
    Damn, the sucks man. Any damage to the pistons/rods or did it just bugger the valves?
    -Alex
  14. #314
    Yes, I could have/should have pulled the head off and removed all the valves. Lesson learned, if a bike sits for an extended period of time (this bike sat for almost 20 years), pull it apart.
    Moving forward once running, it’s important to run the bike a few times a year, and put quality fuel in it.
    There was piston to valve contact in #1 and #4, but it looks like it just took the carbon off the pistons.
    Don't kick yourself too hard over this. It can happen to engines that are in use as well and really, there's no way of knowing unless you disassemble down to that level (and who's honestly going to do that?).
    A boat I owned had a 454 in it that hung a valve during the first startup of the boating season. Thought it was a timing issue, it kept backfiring through the carb so I put a camera in each cylinder and eventually saw the issue.
    Once the engine was pulled out of the hull and the head came off, I discovered the valve hung so hard that I had to punch it all the way out of the guide. Turns out some small piece of unknown material found its way between the valve guide and the stem and that was that.
    Point is, there's simply no way of knowing unless you're already planning for engine disassembly.
    You'll get it sorted because it's in your nature to do so.
    Do you think it'd be helpful to see if anyone on the WERA forum has a stash of head parts kicking around?
    that nos head for $3500 is starting to sound better, get that, and current head machined as a spare
  17. #317
    It can’t hurt to ask anyways. I’m still waiting to hear what parts I actually need for the bike.
    The NOS head is bare, so it doesn’t solve the valve issue.
    Wow, there’s a head available from Yamaha…
    Bad decisions were made today..-img_9275-jpg
    TWINS! xrocket21's Avatar
    Central Maine
    $16k!
    $16k!
    Make a NESR death offer?
    Start a GoFundMe!
    Posted on WERA. If anything comes of it, I'll send you the info.
    Are the valves titanium or sodium filled or some other specialized material? Asking out of curiosity
    Edit:^^ They're titanium
  23. #323
    Got the list of parts needed today, this is what’s needed and unavailable. Most of the universal parts , o rings, nuts, bolts, etc, were still available.
    It’s a long shot, but if anyone can find these, it would be greatly appreciated.
    The exhaust valves, I have 1 good one that can be copied and made (thanks for that contact Bergs) assuming I can’t find new ones.
    Bad decisions were made today..-img_9349-jpg
    Hypertarded
    RI / CT border
    Was chatting with Russell about this yesterday, sounds like an adventure.
    Definitely a bitch, I'm sure you've already looked into custom made gaskets(Cometic / Gasketking), is that a workable option?? or are they too intricate??
    Does your searching include the "dark web"??
    Good luck, i'm sure you'll find them if they're out there...
    None of those part numbers supercede?
    Safe to assume the dealer inventory search was already done?
