Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 126 to 150 of 352
NHMS 2012 Suggestions?
  1. #126
    Re: NHMS 2012 Suggestions?
    Mmmmm kaaayyyyy
  2. #127
    #331 CBR929RE's Avatar
    Bridgewater, MA
    well you can still kinda feel it....but you have to be going kinda fast :
    what is this "fast" you speak of?
    also helps that I don't weigh much more than an 8 year old.
    Mmmmm kaaayyyyy
    so you don't feel it either Mr. Mackey?
  3. #128
    Assuming I'm on my normal line, I say "What bump?"
  4. #129
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    I'll take this softball Brett!:
    also helps that I don't much more [sack? brains? attention span? marbles? .........or maybe...weight? ] than an 8 year old.
    you're welcome
  5. #130
    Bridgewater, MA
    Quote Originally Posted by brady View Post
    you're welcome
    I hate you, I'm glad I moved on up to a nicer place away from that gravel pit you call home.
    one little typo where I miss a whole word and people think its an open invitation.
    Welcome to NESR.
  7. #132
    Bridgewater, MA
    Quote Originally Posted by 07BladeRider View Post
    Welcome to THE INTERWEBZ.
    fixed.
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    I'm certain the spectator attendance would almost assuredly grow if the track put any amount of effort into it.
    jussayyin
    Mike
    Am #124
  9. #134
    Quote Originally Posted by Trackday Guru View Post
    NHMS actually did quite a bit this season with the skybox deal, deals with Roadracing World, etc...
    Eric could tell you better than I could.
  10. #135
    Bridgewater, MA
    and didn't they print up a ton of handouts people can grab at the office to bring to dealerships, group rides, stunt shows, bike nights, or any other motorcycle event.
    if we want more spectator attendance its really up to the racers to help get the word out.
    Banned G21forme's Avatar
    Lakes
    Between me weighing 145 and being slow I have no idea what all the fuss is over said bumps but I would greatly appreciate fixing the t9 tar snakes.
    I've had little to no issue with T9
    ... then again i had no issue with the T1A white line.
    ... or the bumps in 3
    ... or the bumps in 10
    ... or the bump in 1
    ... or the turtle shell in 12
    Don't get me wrong, though. I wouldn't mind a smoother track
    And I DEFINITELY wouldn't mind them smoothing out the entrance to 11, right by the cone on the left. I keep bottoming out the front end when I get on the brakes.
  13. #138
    The only problem I ever had with T9 was I was too chicken to not brake moderately for it.
    Member doug1611's Avatar
    Sep 2010
    Milton, VT
    I think Eric said earlier that the gate prices and fees should go to Tom but thought I would throw this out.
    Like others mentioned reduced fees or group rates would certainly bring more friends / family in.
    I would also suggest having a separate gate fee of $10/15 which would allow people to watch from the stands at the Bowl but not into the infield. This way they could keep the infield pass the same and probably get the same crowd but may draw some additional fans. I know during the Classic they had road signs inviting passer-byes. This way if you had someone who wanted to get a closer look or to be with you they could buy the infield pass. If you had some one that just wanted to take a cruise over to stop by and watch you for a short time they could buy the $10 gate fee and sit at the bowl, you could always go to them. It may also draw the curious passer bye.
    Oct 2005
    Wrentham MA
    re LRRS Novice program
    The program is now even friendlier to new people trying racing. e.g.,faster novices get bumped up to am quicker etc.
    ALL: Tell your friends / spread the word to come try racing, "you're not going to be blown away by super fast guys, everyone is in the same boat".
    Graham
  16. #141
    Last trackday I was getting my speed up through 1, 1a and the bump in T2 was causing me to drift twice way over on the edge of the tire. Once going on, and once going off the patch. I have developed a line I like to call "just the tip" which is a tad wide and just crosses the tip of the triangle. Smooth as butter and better ground clearance.
    May be irrelevant now though if they ground down the bump.
    The bump was ground down when we were there Paul.
    I'm knee over the yellow curbing in 2... I was getting a LOT of drift on worn tires especially on exit, but when I switched to new sneakers she was holding pretty good.
    Try playing with your shock a little?
  19. #144
    My tire was going off for sure. My shock is dialed in pretty amazing, front end is a little stiff... (har, har)
    I always figured you'd had a stiff front end
  21. #146
    Yeah same here. Tires were drifting on the triangle. I followed Paul's line and it worked much better. Will try it out with my new rear next weekend.
    Yeah, but you're increasing distance traveled and sacrificing some drive because you're pointed towards the wall a little more.
    I'd rather deal with a little spinning, get the bike upright a little quicker and get back on the gas sooner.
  23. #148
    True. I feel like at this point I have more confidence with the outside line though and will roll on earlier and harder. Maybe as I get more comfortable with the rear spinning up.
    I found I was getting a little wallow over this new sectiion over the T2 rollercoaster. I brought it tighter to the cones where the transitions are spread out a little further and turned in 1/8-1/4 of rebound to slow the retun rate. Worked out perfectly.
  25. #150
    Distance traveled is farther, but drive was the same or better because we were not spinning or hesitating on the throttle due to the double drift. I think we were going faster through there on the wider line. I'd have to do many timed laps to figure it out exactly though...
    Gino, no wallow for me. Just drifting at the transitions.
  1. 2012 LRRS Suggestions
    Last Post: 10-03-12, 10:35 AM
  2. RRR 2012: Random Rhode island Rides for 2012 thread
    By FriskyDingo in forum Rides & Events
    Last Post: 09-03-12, 11:56 AM
  3. 2012 NHMS Dates - LRRS Practice and School Specials
    Last Post: 04-24-12, 01:55 AM
  4. GPS Suggestions?
    By Femmekat in forum General Bike Related
    Last Post: 05-26-10, 12:41 PM
